Hi all!
I am trying to use GSM module for sending SMS and posting requests. I got it working and all was going well until a moment when GSM module was consantly turning off after 5 seconds. I figured that this was a power supply problem so i bought a battery (this one to be precise http://www.conrad.com/medias/global/ce/6000_6999/6500/6500/6507/650709_BB_01_FB.EPS_1000.jpg). And yeah, after I attached a battery it was powered on normally and also connected to network (netlight blinking). However there seemed to be problem with communication with serial monitor. If I use AT commands nothing happens. I then tried again with power supply from arduino (this time it magically didnt power off after 5 seconds) and communicaiton was normal. Same code, same pins used, same COM port, only difference is with power supply. Any ideas why that would be?
I use this module: http://i.stack.imgur.com/IwIem.jpg
I want to use external supply because im afraid that ill have problems with supply with arduino when I attach GPS module and thermistor to it.
