Weird Problem with StepperMotor Code
So I have this code I made, and basically what it does is when I press the button the motor rotates to the right for X amount of steps. after this is done Led 1 turns on and Led2 turns off and i can press the button again. When I press the button again, the motor rotates the other side and Led 2 turns on and led1 off... you get the idea.
But the weird thing is that at random moments the motor rotates glitchy or back and forth for a little... Most of the times it just works smooth, but for my particular project I cant have these bugs since im working with a precise amount of steps it has to complete.
Could anyone check my code and find out why it might bug sometimes? cuz I am at a loss
P.S. I did get some parts of the code from internet, so ignore the names like relaypin and some comments... these relaypins go toward the LEDs
int pbuttonPin = 7;// connect output to push button
int relayPin = 10;// Connected to relay (LED)
int relayPin2 = 11;// Connected to relay (LED)
int val = 0; // push value from pin 2
int lightON = 0;//light status
int pushed = 0;//push status
#define step_pin 3
#define dir_pin 2
#define MS1 5
#define MS2 4
int dir;
int steps = 3000;
  pinMode(pbuttonPin, INPUT_PULLUP);
  pinMode(relayPin, OUTPUT);
  pinMode(relayPin2, OUTPUT);
 digitalWrite(relayPin, HIGH);// keep the load OFF at the begining. If you wanted to be ON, change the HIGH to LOW
 digitalWrite(relayPin2, HIGH);// keep the load OFF at the begining. If you wanted to be ON, change the HIGH to LOW
  pinMode(MS1, OUTPUT);
  pinMode(MS2, OUTPUT);
  pinMode(dir_pin, OUTPUT);
  pinMode(step_pin, OUTPUT);
  digitalWrite(MS1, LOW);
  digitalWrite(MS2, LOW);
  digitalWrite(dir_pin, HIGH);
  val = digitalRead(pbuttonPin);// read the push button value
  if(val == HIGH && lightON == LOW){
    pushed = 1-pushed;
  lightON = val;
      if(pushed == LOW){
        Serial.println("Light ON");
        digitalWrite(relayPin2, LOW);
        digitalWrite(dir_pin, LOW);
        else{
        Serial.println("Light OFF");
        digitalWrite(relayPin, LOW);
if (val == LOW){
  Motor();
  delay(100);
void Motor(){
  steps = 3000;
       while(steps > 0) {
    digitalWrite(step_pin, HIGH);
    delay(1);
    digitalWrite(step_pin, LOW);
    delay(1);
    steps--;
    return;
The ususal suspects: Power supply too weak, power supply gives in, timing wrong, acceleration too high, stepper driver cannot cope with motor, current limiting set too high.
Usual problem, no list of web links for components used, no circuit schematic diagram, no photos taken in daylight of the whole assembly. :roll_eyes:
