I have a weird problem that I’m hoping someone can help me to troubleshoot. This is on an ATMega 2560 being compiled on MacOS X Mountain Lion.
I’m working on interfacing with an 80x7 lightboard. I’ve written the interface code, and I can control any pixel and color. Now I’m writing the code to actually display characters.
Here is the relevant code (this is just an example, it won’t compile):
PROGMEM struct character_t {
byte col1;
byte col2;
byte col3;
byte col4;
byte col5;
} font[] = {
{ B00000000, B00000000, B01011111, B00000000, B00000000},
{ B00000000, B00000011, B00000000, B00000011, B00000000},
{ B00010100, B00111110, B00010100, B00111110, B00010100},
NULL
void printChar(unsigned char c, byte offset) {
byte array_offset = 0;
byte i;
Serial.println(c);
array_offset = c - 33;
Serial.println(array_offset);
for (i = 0; i < 7; i++) {
if ((font[array_offset].col1 >> i & B00000001) == 1) {
setPixel(offset, i, 2, 0);
setPixel(offset, i, 0, 0);
if ((font[array_offset].col2 >> i & B00000001) == 1) {
setPixel(offset + 1, i, 2, 0);
setPixel(offset + 1, i, 0, 0);
if ((font[array_offset].col3 >> i & B00000001) == 1) {
setPixel(offset + 2, i, 2, 0);
setPixel(offset + 2, i, 0, 0);
if ((font[array_offset].col4 >> i & B00000001) == 1) {
setPixel(offset + 3, i, 2, 0);
setPixel(offset + 3, i, 0, 0);
if ((font[array_offset].col5 >> i & B00000001) == 1) {
setPixel(offset + 4, i, 2, 0);
setPixel(offset + 4, i, 0, 0);
printChar('!', 0);
The first bit of code defines character structures - I’ve got three (a !, ", and #). The second bit of code is supposed to print one character to the board at x offset offset. The third function is obvious and calls the print routine.
The issue is this: passing the character into the function as ‘c’ just doesn’t work. If I set array_offset to 0 in the code, it works (prints a ! at offset 0). If I reset c (c = 33) in the printChar function it works properly. If I do neither I get random pixels being activated. I’ve debugged the code to the point where I know that array_offset is the correct value in all cases, and c is the correct value in all cases. So I simply don’t understand why the code will not work if I pass in the character as the argument.
Has anyone else seen anything like this?
