I have a strange error with my problem. I wrote the code for an XBee and SD card, and now, when adding the one for Adafruit GPS, the board acts very strange. If i comment some function declarations, then it works. It seems that it's too much code in my project, but it is only 77%. Anyone had this problem before?
cyb3rman:
Probably. If you are using an Uno, you may be running out of SRAM. You might try using the F() macro to keep static strings in program memory.
Thanks
I forgot to mention: the board resets ~10 times right after the first Serial.println() when i open the COM port in Visual Studio.
I'll try what you said and come back with an answer.
Thank you for the answers!
I had a lot of strings printed through Serial for debug purposes, and I just put them into Flash memory with F()
It works perfect now.. (for the moment).
OFFTOPIC: It's a little frustrating with all these limitations... Is there a list with microcontrollers that are compatible with arduino bootloader?
cyb3rman:
