Hello all,
I recently learned about using the PSTR() macro and variables stored in PROGMEM to contain large strings, so as to minimize their impact on RAM. This helped me solve some problems I was having running out of RAM. But now I have a new problem: if I define too many strings in PSTR, the application crashes like it did before.
The full application (including the two libraries I'm using, MatrixDisplay and Ethercard) can be found here: GitHub - bklang/tankersign: Jill's personal LED sign, handcrafted by master artisans
A few notes on the application:
This application is running on an Arduino Uno and has an ENC28J60 network card, as well as 4 Sure Electronics DE-DP13111 32x8 LED matrices. The goal is to receive network packets containing short bits of text and display them on the LED display.
I'm using the globally defined "messages" variable as the placeholder to write text that will be scrolled out to the LED display
I've commented out a lot of functionality to debug, so the only thing it's actually doing right now is showing the amount of free memory on the display, unless a network request comes in, in which case it shows a messages to that effect.
The problem is this: when I add one more 22-character string with a PSTR(), or even if I pad any of the existing strings with just 22 more bytes (eg. "AAAAAAAAAAAAAAAAAAAAAA"), the application crashes and tends to behave like it has run out of memory.
With the extra strings commented out, the display shows me my free memory. Regardless of the number or length of PSTR() log strings, my display reports 204 bytes of RAM free, so I don't think I'm running out of RAM.
The Arduino IDE shows:
The sketch is using 15,158 bytes (46%) of program space. The maximum is 32,256 bytes.
Global variables are using 1,473 byte (71%) of dynamic memory, leaving 575 bytes free for local variables. The maximum is 2,048 bytes.
This makes me think I've got more than enough program space available for more PSTR() uses. So why does adding length to these strings cause my program to fail? Any hints on troubleshooting?
