Weird results with XBEE on baud rates >9600
Hey there,
I have a really weird problem. I am interfacing 5 arduino's with xbees,, one set in zigbee coord API and the other four in End Mode API, at least, that is the goal. Right now i have one coord and two end points. All is going well on 9600 baud, except for a little delay because I need higher baud rates. But when I switch to a higher baud rate, all the arduino seems to get is zeroes. The xbees send the data well, I checked with the XCTU utility, just the arduino fails to read the packet properly. I use this as test code
int incomingByte; void setup(){ Serial.begin(115200); }
void loop(){ if(Serial.available()>0){ incomingByte=Serial.read();
Serial.print(incomingByte); } }
When I send data over USB, it works fine, and in a very rare occasion after sending over USB and resetting the XBEE a couple of times (but unclear in what order) it receives the XBEE packet correct, but that is far from reliable of course.
Anyone got a clou?
Regards, Albert van Andel
