Weird Serial2/Serial3 problem
I am trying to communicate with a GSM shield (iComSat) using my arduino Mega’s serial2 port (pin16, pin 17).
My code is as follows:
#include <string.h>
char incoming_char=0;
  Serial2.begin(9600);
  Serial.println("Starting Communication...");
  if(Serial2.available() >0)
    incoming_char=Serial1.read();
    Serial.print(incoming_char);
  if(Serial.available() >0)
    incoming_char=Serial.read();
    Serial2.print(incoming_char);
The problem is that when I use serial2 (or serial3), as soon as I send any AT command (even just “AT”) the terminal program (Bray’s terminal) just starts printing periods like so: …
and so on, until I disconnect.
Now if I switch my setup and use serial1 instead, everything works as it should.
Does anyone have any idea of what could be going wrong? Is my board broken/fried?
Are you sure this is correct?
If you check Serial2, you should read Serial2.
Opps!
I'm sorry for wasting your time. I can't believe I didn't see that.... :blush:
Thanks for the help. It works perfectly now!
Sparked:
Opps!
If it works, you didn't waste my time at all! :slight_smile:
