Weird string when i try to print hex as a string
hi so i've been trying to convert an int to a hexadecimal string some conversions work but when i try to print it in the monitor i get:
FFáâ7ó^}eøõ6‡·èÀ»[ðÿÿ‰âïå“}÷Žî֓ëõòQ÷źþkþÓù¦t|¼ýûßÏÿNOŒ;×ð]§€\ø™8WçÿM±¸½—š†¸ã/ó
here is my code
void loop(){
  String string_Of_Hex_Numbers;
  Decimal_To_Hex(255, string_Of_Hex_Numbers);
  Serial.println(string_Of_Hex_Numbers);
void Decimal_To_Hex(int decimal_Number_To_Be_Converted_To_Hex, String &hex_Number_Array_As_String){
   int place_Of_Hex_Symbol = 0;
   char hex_Number_Array[100];
   long quotient = decimal_Number_To_Be_Converted_To_Hex;
   long remaining_Number_After_Devision;
   while (quotient != 0)
     //first we do a modulo on the quotient to see what remains
     //then we assign a symbol to it
       remaining_Number_After_Devision = quotient % 16;
       if (remaining_Number_After_Devision < 10){
           hex_Number_Array[place_Of_Hex_Symbol++] = 48 + remaining_Number_After_Devision;
           quotient = 0;
       else{
           hex_Number_Array[place_Of_Hex_Symbol++] = 55 + remaining_Number_After_Devision;
           quotient = quotient / 16;
   hex_Number_Array_As_String = String(hex_Number_Array);
does anyone know where my error could be?
thanks in advance
From a brief look, i'd say your code is working. You get FF which is correct for 255. You just forgot to terminate the array of characters in hex_Number_Array[].
Try changing this:
to
hex_Number_Array[place_Of_Hex_Symbol] = 0;
of course you could also do
  Serial.println(255, HEX);
void loop(){}
yes this is awesome. I am printing the string in reverse but i can find a way to flip it so thats easy enough.
this would work but I need the value as a string not as an int :frowning:
Why do you need it as a string?
  char hex_string[6];
  snprintf(hex_string,sizeof(hex_string);"%X",255);
  Serial.println(hex_string);
void loop(){}
Or, for much smaller but less flexible code, use itoa():
itoa(255, hex_string, 16);
I was wondering which direction this was going… :clown_face:
