Weird stuff in the TLC5940 library
Hello everyone.
I have found some differences between the wiring scheme
http://tlc5940arduino.googlecode.com/svn/wiki/images/breadboard-arduino-tlc5940_close.png
and the description in the arduino TLC5940 library. Please pay attention on the connection where +5 V come in
    Basic Pin setup:
                        ------------                                     ---u----
    ARDUINO   13|-> SCLK (pin 25)                 OUT1 |1     28| OUT channel 0
                    12|                                         OUT2 |2     27|-> GND (VPRG)
                    11|-> SIN (pin 26)                    OUT3 |3     26|-> SIN (pin 11)
                    10|-> BLANK (pin 23)               OUT4 |4     25|-> SCLK (pin 13)
                      9|-> XLAT (pin 24)                       .  |5     24|-> XLAT (pin 9)
                      8|                                               .  |6     23|-> BLANK (pin 10)
                      7|                                               .  |7     22|-> GND
                      6|                                               .  |8     21|-> VCC (+5V)
                      5|                                               .  |9     20|-> 2K Resistor -> GND
                      4|                                               .  |10    19|-> +5V (DCPRG)
                      3|-> GSCLK (pin 18)                     .  |11    18|-> GSCLK (pin 3)
                      2|                                               .  |12    17|-> SOUT
                      1|                                               .  |13    16|-> XERR
                      0|                                         OUT14|14    15| OUT channel 15
    -  Put the longer leg (anode) of the LEDs in the +5V and the shorter leg
         (cathode) in OUT(0-15).
    -  +5V from Arduino -> TLC pin 21 and 19     (VCC and DCPRG)
    -  GND from Arduino -> TLC pin 22 and 27     (GND and VPRG)
    -  digital 3        -> TLC pin 18            (GSCLK)
    -  digital 9        -> TLC pin 24            (XLAT)
    -  digital 10       -> TLC pin 23            (BLANK)
    -  digital 11       -> TLC pin 26            (SIN)
    -  digital 13       -> TLC pin 25            (SCLK)
The two little red wires with the resistor between them seem to be connecting +5V to pins 19 and 21, just as the chart calls for.
but what about 23?
Uptown:
but what about 23?
There's a 10K pull-up resistor and a blue wire to Arduino Pin 10.
