Weird TIMER1 behavior (simple square wave using interrupt)
Hello all,
I’m writing here after a lot of unsuccessful tests on what should be a VERY simple task: making a 38 kHz square wave using TIMER1 on a UNO board. After reading a lot of (but very scattered) information regarding TIMER1 features, I ended with these conclusions:
  • choose TIMER1 for this purpose;
  • use CTC on compare match;
  • setup OC1A pin in toggle mode.
With this configuration, it should be possible to have a square wave on OC1A pin (Arduino pin 9) even without calling any ISR. Indeed here’s my code on setup() section:
  // timer1 initialization
  noInterrupts(); // disable all interrupts
  TCCR1A = 0;
  TCCR1A |= (1 << COM1A0);             // setup OC1A pin in toggle mode
  TCCR1B = 0;
  TCCR1B |= (1 << WGM12);              // clear timer/counter 1 on compare match
  TCCR1B |= (1 << CS10);               // no prescaler (timer clock = system clock)
  TCNT1 = 0;                           // reset counter
  OCR1A = 210;                         // set value on TCNT1 for given IR frequency (AVRCLOCK/IRFREQUENCY/2)
  TIMSK1 |= (1 << OCIE1A);             // enable timer compare interrupt
  TIFR1 = (1<<OCF1B);
  interrupts();                        // enable all interrupts
On main() section the program simply does nothing. Capturing the signal on pin 9 (with a DSO) I obtain a signal which doesn’t have a 38 kHz frequency, doesn’t have a 50% duty cycle (as I was expecting) and, above all, has this strange waveform: Capture — ImgBB
Obviously, I’m missing something… but what? Can someone help me in this fairly simple task?
Thanks in advance.
Gabriele.
Why are you enabling this interrupt? Where’s your ISR?
In fact I don't exactly know why should I enable interrupts: I don't need an ISR (and there isn't any ISR routine on my code) because the toggle function on OC1A pin (Arduino pin 9) is all that I need for generating a square wave: it toggles at every compare match between counter 1 and OCR1A register. Do you think I only need to disable that flag? Thanks in advance.
gabrielebellini: Do you think I only need to disable that flag?
I don't know. Try it.
gfvalvo: I don't know. Try it.
You're right! Resetting that flag prevented the (useless) ISR call and thus the unexpected waveform disappeared! Now I have the correct frequency, duty cycle and waveform! Thank you so much!!!!
