Im sorry, I was doing a draft, here is the copmplete code;
The problem is in the OFF state machine, The ON works
//=====================================LIBRERIAS==================================================//
#include <Wire.h>
#include <OneWire.h>
#include <dht.h> //Libreria para DTH
#include <DallasTemperature.h> //Libreria Ds1820
#include <LiquidCrystal_I2C.h> //Libreria IC2
//=====================================COSNTRUCTORES =============================================//
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
const byte dif1 = 6;
const byte dif2 = 7;
byte currentFan = 0;
boolean fanWasOn = true;
boolean pasWasOn = false; //para prueba
byte fans[]={dif1, dif2};
//-----------VAR FOR THE ON STATE MACHINE
unsigned long delaysONfans[4] = {3000, 6000, 9000, 12000 };
unsigned long fanONtime = 0; //the time for the function On
int secondON = 0;
int pasSeconON = 0;
int pasSecondON = 0;
byte fanCase = 2;
boolean cycleON = false;
boolean timerON = false;
byte ventON = 1;
//-------para prueba
byte pasCurrentFan = 1;
byte pasTimerON = 0;
//----var for the off state machine
boolean timmerOFF = false;
boolean pasTimerOFF = true;
unsigned long fanOFFTime = 0; //the time for the function Off
unsigned long delayOFFFans[4] = {6000, 12000, 18000, 24000 };
int ventOFF = 1;
int pasVentOFF = 0;
int secondOFF = 0;
int pasSecondOFF =0 ;
void setup(){
lcd.begin(20,4);
void loop(){
cycleFans();
void cycleFans(){
//-----roll over the variable to keep starting only two fans
if(currentFan > 2) currentFan = 0;
//-----this only allow one state and start each SM
//prints once the changue of the variable
if(fanWasOn =! pasWasOn){
Serial.println("--El ciclo ha cambiado--");
pasWasOn = fanWasOn ;
//prints once the name of the fans
if(currentFan != pasCurrentFan){
if(currentFan == 0) Serial.println( " VENTILADOR IZQUIERDO " ); Serial.println(" ");
if(currentFan == 1) Serial.println( " VENTILADOR DERECHO " );Serial.println(" ");
pasCurrentFan = currentFan;
// SM for the Ventilation ON
switch(ventON){ //if the fan was on, we will use the apropiated timmer
case 1 : // start the variables.
if(timerON != pasTimerON)
Serial.println("Caso 1 ventilacion Encendida");
lcd.clear();
lcd.setCursor(0,0); lcd.print(F(" CASO 1 "));
pasTimerON = timerON;
fanONtime = millis() - 100 ; // start the cronometer each time
ventON++; //jump to the next SM state
case 2 : //print the lcd to keep data clear
Serial.println("Caso 2 ventilacion Encendida");
Serial.println("------IMPRIMIENDO LCD-------");
lcd.clear();
lcd.setCursor(0,0); lcd.print(F(" UN SOLO VENTILADOR "));
lcd.setCursor(0,1); lcd.print(F(" ENCENDIDO POR "));
lcd.setCursor(0,2); lcd.print(" ");
lcd.setCursor(0,3); lcd.print(F(" TEMP 10.00 C "));
ventON++;//jump to the next SM state
Serial.print ("VentON = "); Serial.println (ventON);
case 3 :
// start the timmer while the fans is keep OFF
Serial.println("Caso 3 ventilacion Encendida");
Serial.print ("millis = "); Serial.println ( millis() );
Serial.print ("fanONtime = "); Serial.println (fanONtime);
Serial.print ("M-FON time= "); Serial.println (millis() - fanONtime);
Serial.print ("Delay = "); Serial.println (delaysONfans[fanCase]);
Serial.println("-------------------------------------------------");
if( millis() - fanONtime <= delaysONfans[fanCase]) //chek if the time has expired
digitalWrite(fans[currentFan], LOW); //turn on a fan during the current delay on
secondON = (( delaysONfans[fanCase] - millis() ) / 1000 );
if ( secondON - pasSecondON != 0 ) //this will only prints on the lcd one second elapsed
lcd.setCursor(0,2); lcd.print( secondON );
Serial.println (secondON );
//Serial.print(pasSecondON); Serial.println(secondON);
pasSecondON = secondON;
else { ventON++; } // if the timmer is off jump to the next state of the FM
case 4 : //re -start all the variables, inicialized the next state of the FM
Serial.println("Caso 4 ventilacion Encendida");
Serial.println(" REINICIANDO VARIABLES ");
secondON = 0;
pasSecondON = 0;
fanWasOn = false;
ventON = 0;
ventOFF = 1;
lcd.clear();
}//end of function
// SM for the Ventilation OFF
switch(ventOFF){ //if the fan was on, we will use the apropiated timmer
if(timmerOFF != pasTimerOFF)
Serial.println("Caso 1 ventilacion Apagada");
//lcd.clear();
//lcd.setCursor(0,0); lcd.print(F(" CASO 1 "));
pasTimerOFF = timmerOFF;
fanOFFTime = millis() - 10 ; // start the cronometer each time
ventOFF++; //jump to the next SM state
Serial.println("Caso 2 ventilacion Apagada ");
lcd.clear();
lcd.setCursor(0,0); lcd.print(F("VENTILACION APAGADA "));
lcd.setCursor(0,1); lcd.print(F(" POR "));
ventOFF++;//jump to the next SM state
Serial.print ("VentOFF = "); Serial.println (ventOFF);
case 3 :
Serial.println("Caso 3 ventilacion Apagada");
Serial.print ("fanOfftime= "); Serial.println (fanOFFTime);
Serial.print ("Delay = "); Serial.println (delayOFFFans[fanCase]);
Serial.print ("M-OFF time= "); Serial.println (millis() - fanOFFTime);
if( millis() - fanOFFTime < 12000 ) //chek if the time has expired
//if( millis() - fanOFFTime < delayOFFFans[fanCase]) //chek if the time has expired
digitalWrite(fans[currentFan], HIGH); //turn OFF a fan during the current delay on
secondOFF = (( delayOFFFans[fanCase] - millis() ) / 1000 );
// if ( pasSecondOFF >= 0 ) //this will only prints on the lcd one second elapsed
if ( secondOFF - pasSecondOFF != 0 ) //this will only prints on the lcd one second elapsed
lcd.setCursor(0,2); lcd.print( secondOFF );
Serial.print ("pasSecondOFF = "); Serial.println(pasSecondOFF);
Serial.print ("SecondOFF = "); Serial.println(secondOFF);
pasSecondOFF = secondOFF;
else { ventOFF++; } // if the timmer is off jump to the next state of the FM
Serial.println("Caso 4 ventilacion Apagada");
secondOFF = 0;
pasSecondOFF = 0;
ventOFF = 0;
ventON = 1;
fanWasOn = false;
lcd.clear();
}//end of function
