Weird UART baud rate on STM32 Nucleo-H7
I'm using NUCLEO-H743ZI2 with Arduino environment. I try tu use it, actually. The problem is that baud rate for TX data is different than it should be. E.g. when I set 9600 and try to decode a message with an oscilloscope, I get garbage. The highest baud rate I can set on the oscilloscope to correctly decode the message (supposedly sent at 9600) is 9400. Does anyone have any idea what this could be? (My NUCLEO-F446RE works fine.)
Solved.
It turns this Nucleo board version was configured in stm32duino to use I think the worst clock option, that is CSI, which is an internal 4 MHz RC oscillator. The result was that the UART was 6% too slow. I could've tried to calibrate the oscillator, but I didn't bother.
Instead, I used STM32CubeMX and knowledge from this course https://www.udemy.com/microcontroller-programming-stm32-timers-pwm-can-bus-protocol/ (I highly recommend courses by this author) to configure the MCU to use external clock provided by the onboard STLink programmer. This clock is 8 MHz and is derived from a crystal.
The clock had to be configured to use HSE (High Speed External) oscillator set to bypass mode -- i.e. we connect a digital clock signal instead of a crystal.
So, in variant.cpp pertaining to my board I changed the old function
WEAK void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct;
  /* Supply configuration update enable */
  MODIFY_REG(PWR->CR3, PWR_CR3_SCUEN, 0);
  /* Configure the main internal regulator output voltage */
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  while ((PWR->D3CR & (PWR_D3CR_VOSRDY)) != PWR_D3CR_VOSRDY) {
  /* Initializes the CPU, AHB and APB buses clocks */
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI48 | RCC_OSCILLATORTYPE_CSI;
  RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
  RCC_OscInitStruct.CSIState = RCC_CSI_ON;
  RCC_OscInitStruct.CSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_CSI;
  RCC_OscInitStruct.PLL.PLLM = 1;
  RCC_OscInitStruct.PLL.PLLN = 200;
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  RCC_OscInitStruct.PLL.PLLR = 2;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_2;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1VCOWIDE;
  RCC_OscInitStruct.PLL.PLLFRACN = 0;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) {
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK
                                | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2
                                | RCC_CLOCKTYPE_D3PCLK1 | RCC_CLOCKTYPE_D1PCLK1;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.SYSCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_APB3_DIV2;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_APB1_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_APB2_DIV2;
  RCC_ClkInitStruct.APB4CLKDivider = RCC_APB4_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK) {
    Error_Handler();
  PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_ADC | RCC_PERIPHCLK_USB;
  PeriphClkInitStruct.PLL2.PLL2M = 1;
  PeriphClkInitStruct.PLL2.PLL2N = 129;
  PeriphClkInitStruct.PLL2.PLL2P = 2;
  PeriphClkInitStruct.PLL2.PLL2Q = 2;
  PeriphClkInitStruct.PLL2.PLL2R = 2;
  PeriphClkInitStruct.PLL2.PLL2RGE = RCC_PLL2VCIRANGE_2;
  PeriphClkInitStruct.PLL2.PLL2VCOSEL = RCC_PLL2VCOWIDE;
  PeriphClkInitStruct.PLL2.PLL2FRACN = 0;
  PeriphClkInitStruct.UsbClockSelection = RCC_USBCLKSOURCE_HSI48;
  PeriphClkInitStruct.AdcClockSelection = RCC_ADCCLKSOURCE_PLL2;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK) {
    Error_Handler();
to a function generated by STM32CubeMX after properly setting the clock tree
		RCC_OscInitTypeDef RCC_OscInitStruct = {0};
		RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
		RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
		/** Supply configuration update enable
		HAL_PWREx_ConfigSupply(PWR_LDO_SUPPLY);
		/** Configure the main internal regulator output voltage
		while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
		/** Configure LSE Drive Capability
		HAL_PWR_EnableBkUpAccess();
		__HAL_RCC_LSEDRIVE_CONFIG(RCC_LSEDRIVE_LOW);
		/** Macro to configure the PLL clock source
		__HAL_RCC_PLL_PLLSOURCE_CONFIG(RCC_PLLSOURCE_HSE);
		/** Initializes the CPU, AHB and APB busses clocks
		RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE|RCC_OSCILLATORTYPE_LSE;
		RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
		RCC_OscInitStruct.LSEState = RCC_LSE_ON;
		RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
		RCC_OscInitStruct.PLL.PLLN = 100;
		RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1VCIRANGE_3;
			Error_Handler();
		RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
		|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
		|RCC_CLOCKTYPE_D3PCLK1|RCC_CLOCKTYPE_D1PCLK1;
			Error_Handler();
		PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RTC|RCC_PERIPHCLK_USART3
		|RCC_PERIPHCLK_ADC|RCC_PERIPHCLK_USB;
		PeriphClkInitStruct.PLL2.PLL2M = 4;
		PeriphClkInitStruct.PLL2.PLL2N = 100;
		PeriphClkInitStruct.PLL2.PLL2RGE = RCC_PLL2VCIRANGE_1;
		PeriphClkInitStruct.PLL3.PLL3M = 2;
		PeriphClkInitStruct.PLL3.PLL3N = 48;
		PeriphClkInitStruct.PLL3.PLL3P = 2;
		PeriphClkInitStruct.PLL3.PLL3Q = 4;
		PeriphClkInitStruct.PLL3.PLL3R = 2;
		PeriphClkInitStruct.PLL3.PLL3RGE = RCC_PLL3VCIRANGE_2;
		PeriphClkInitStruct.PLL3.PLL3VCOSEL = RCC_PLL3VCOWIDE;
		PeriphClkInitStruct.PLL3.PLL3FRACN = 0;
		//PeriphClkInitStruct.Usart234578ClockSelection = RCC_USART234578CLKSOURCE_D2PCLK1;
		PeriphClkInitStruct.UsbClockSelection = RCC_USBCLKSOURCE_PLL3;
		PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
			Error_Handler();
		/** Enable USB Voltage detector
		HAL_PWREx_EnableUSBVoltageDetector();
Also, in stm32h7xx_hal_conf_default.h I changed
#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
to
#define HSE_VALUE    ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
to indicate proper clock frequency.
Both of these changes I could've done without modifying the original default files, but I didn't bother. To me the options I used should be the default ones.
