Weirdness with Serial.read() - extra character?
I am having a weird problem with the program below. Basically it is designed to read an ascii character, followed by a 3 digit decimal number, and use that to position a servomotor and return a sensor reading.
For example, a message would look like ‘a123’ - the ‘a’ would be stripped off, the ‘123’ converted to an integer with that value, etc.
The weirdness is this: the initial ‘a’ is read correctly, and the right case statement chosen. However, the first of the numeric characters read is always a byte with a value of 255! The next two bytes are the correct ascii values for the first two digits of the numeric parameters. It is as if an extra byte was sneaking in between the ‘a’ and the ‘123’.
Rangefinder control
Gian Pablo Villamil
October 10, 2006
This program waits for a signal from processing to move to an angle, then returns a
rangefinder reading at that angle.
int servoPin = 9; // Control pin for servo motor
int minPulse = 500; // Minimum servo position
int maxPulse = 2500; // Maximum servo position
int pulse = 0; // Amount to pulse the servo
int lastPulse = 0; // the time in milliseconds of the last pulse
int refreshTime = 20; // the time needed in between pulses
int analogValue = 0; // the value returned from the analog sensor
int analogPin = 0; // the analog pin that the sensor’s on
int rangeFinderValue = 0;
int rangeFinderPin = 1;
int servoAngle = 0;
byte incomingByte ;
int scale(int inputValue, int inputMin, int inputMax, int outputMin, int outputMax);
void moveServoTo(int angle) ;
void returnReading() ;
pinMode(servoPin, OUTPUT); // Set servo pin as an output pin
pulse = minPulse; // Set the motor position value to the minimum
servoAngle = 0;
lastPulse = millis();
if (Serial.available()) { // message available?
incomingByte = Serial.read();
switch (incomingByte) { // what is it?
case ‘a’:
// set servo angle and get reading
servoAngle = 0;
for (int i = 0; i <=2; i++) {
Serial.println(incomingByte,DEC);
servoAngle = servoAngle * 10 + (incomingByte - 48);
Serial.print("received servoangle = ");
Serial.println(servoAngle);
pulse = scale(servoAngle,0,255,minPulse,maxPulse);
Serial.print("pulse = ");
Serial.println(pulse);
moveServoTo(pulse); // move the motor
returnReading(); // return the reading
break; // Break from the switch
case ‘i’:
// set minimum
Serial.println(“minimum”);
case ‘o’:
// set maximum
Serial.println(“maximum”);
while (Serial.available()) {
incomingByte = Serial.read(); // clear the buffer
// if nothing else happened, refresh the servo
if (millis() - lastPulse >= refreshTime) {
moveServoTo(pulse);
lastPulse = millis(); // save the time of the last pulse
void moveServoTo(int pulse) {
digitalWrite(servoPin, HIGH); // Turn the motor on
delayMicroseconds(pulse); // Length of the pulse sets the motor position
digitalWrite(servoPin, LOW); // Turn the motor off
void returnReading() {
rangeFinderValue = analogRead(rangeFinderPin);
Serial.print("r "); // we are returning a reading
Serial.print(rangeFinderValue, DEC); // send the reading
Serial.println(); // send a carriage return
int scale(int inputValue, int inputMin, int inputMax, int outputMin, int outputMax) {
return ((outputMax-outputMin)*(inputValue-inputMin)/(inputMax-inputMin)+outputMin);
255 (or -1) is the value returned by Serial.read() when no character is available. It sounds as though you're trying to read the characters faster than they are arriving on the serial connection. Try adding a delay before the second Serial.read() call, or check that more than one byte is available with Serial.available().
Thanks! That did the trick!
