Hello
I need your help because I try to connect my 2 boards WEMOS D1 and SIM900 GSM/GPRS Shield but I dont understand which pin I must connect
Is someone know how to connect it ?
And how test it ?
Many thanks by advance
Hello
And how test it ?
which Wemos D1 is it?
have a look at software-serial-esp8266 which you should be able to use to connect the D1 to ethe SIM900
It's the WeMos D1 WiFi UNO like WeMos
just connected up a Wemos D1 mini pro to a SIM900
using the following code
// ESP8266 SoftwareSerial
// https://circuits4you.com/2016/12/14/software-serial-esp8266/
#include <SoftwareSerial.h>
// pins Rx GPIO14 (D5) and Tx GPIO 12 (D6)
SoftwareSerial swSer(D5, D6);//14, 12);
Serial.begin(115200); //Initialize hardware serial with baudrate of 115200
swSer.begin(9600); //Initialize software serial with baudrate of 115200
Serial.println("\nESP8266 Software serial test started");
while (swSer.available() > 0) { //wait for data at software serial
Serial.write(swSer.read()); //Send data recived from software serial to hardware serial
while (Serial.available() > 0) { //wait for data at hardware serial
swSer.write(Serial.read()); //send data recived from hardware serial to software serial
D1 serial monitor displays
RDY
+CPIN: NOT INSERTED
+CFUN: 1
at
OK
AT+cgmi
SIMCOM_Ltd
OK
AT+CGMM
SIMCOM_SIM900
OK
Edit: connected up a Wemos D1 same as yours SIM900 RXD to D6 and TXD to D5
works OK
Ok so for you D6 is pin named D12/MISO/D6 and D5 is pin named D13/SKD/D6 on Wemos ?
And where is the RXD and TXD on SIM 900 ? We use Hardware Serial (D0 D1) or Software Serial (D7 D8) ?
Many thanks for your feed back
Many thanks ..
I busy now but I will test it quickly
Hello horace
Many thanks for your help but it seem to not ok for me
I take photos about cards and program but
swSer.available() is always equal to 0
https://ibb.co/vx0Dz19
https://ibb.co/MSR3FV4
I not put SIM card in SIM900
I you have idea about my errors, i take
Many tanks
Hello
I tested le SIM900 by FTDI connection with AT command and all is ok
I tried to send au SMS and read it
So I connect Wemos to SIM900 like schema and use the sketch but nothing work ok
I select LOLIN (WEMOS) D1 R2 & mini in Arduino IDE and user serial library
name=SoftwareSerial
version=1.0
author=Peter Lerup
maintainer=Peter Lerup peter@lerup.com
sentence=Implementation of the Arduino software serial for ESP8266.
paragraph=
category=Signal Input/Output
url=
architectures=esp8266
Have you an idea about misteke
Many thanks
when you press the SIM900 button to switch it on does anything appear on the serial monitor even garbage?
how are you powering the SIM900?
it may be in autobaud mode try typing at at at a number of times
When I turn on the SIM900 nothing display on serial
When i press the D1 button,
SDK:2.2.2-dev(38a443e)/Core:3.1.1=30101000/lwIP:STABLE-2_1_3_RELEASE/glue:1.2-65-g06164fb/BearSSL:b024386
I powering the SIM with 5V 2A alimentation and I try typing at but nothing.
I looking for again
when you power the SIM900 the PWR LED should light
if you press the PWRKEY on the SIM900
and the following appear on the serial monitor
RDY
+CPIN: NOT INSERTED
+CFUN: 1
should then be able to enter AT commands - note line ending should be Carriage Return or NL & CR
