Wemos D1 Booting Problem
I’ve been really struggling with a WEMOS D1 Mini. When I power it with regulated 5v it doesn’t boot until you press reset.
I’ve pulled up every GPIO+RST except GPIO15 which is directly grounded.
When I power it up and test voltage, GPIO0 shows 1.6v (presumably low?!) whereas GPIO2 (next to it) shows 3.3v. These are pulled up using 4k7 resistors off the 5v line. I tried off the 3.3v previously, same result.
Here are a couple of photos - this is my second attempt to get this board working, and I’ve tried many, many suggestions I’ve read online.
You will see 2 regulators and a big cap next to one of them - these 2 parts are not currently used. I intended this to provide a separate 5v to power the LCD, just in case it was a power issue.
I do have caps on the 5v and 3.3v lines.
I’ve tried two different Wemos D1 Pro boards. I’ve also painstakingly recreated the circuit twice with the same results.
I was previously using an ESPDuino with a screw shield, and near identical circuitry - that one always boots despite identical connections to the same pins.
Very stuck!! Any help would be much appreciated.
GPIO0 should be 3.3V. Check your connections and solder joints, maybe it's shorted to ground somewhere.
You shouldn't add any external pull-up or pull-down resistors, everything you need to run the ESP8266 are on the board. Shorting GPIO15 directly to ground is a very bad idea.
Pulling the pins of a 3.3V device up to 5V doesn't make much sense either.
Pieter
Thanks - i've tried that, by rebuilding it twice.
I've just done a test where the only connections are 5v,GND and the two I2C pins. Still doesn't boot until you press the reset button.
There are two posts i came across whilst googling, much the same problem, but inconclusive results:
https://forum.wemos.cc/topic/65/problems-booting-with-5v-pin-power-supply
