WEMOS D1 / Conflict with MPU6050 RTC SD Card
Using :
Wemos D1 mini pro
RTC DS1307 with Micro SD For WeMos D1 mini Data Logger DataLog Shield
MPU6050
I was not able to find the RTC and SD Card combine shield so they are separeted on the schematic.
I have tested the sketch before connecting the shield and I was able to send the accelerations to Influxdb.
Once I connected the RTC/SD Card shield, I'm not able to transfer the sketch. I's not connecting.
If I disconnect the shield, It loads the code.
I reconnect the shield and it's not able to communicate with the MPU6050.
I'm pretty shure it's related to MPU6050 AD0 and INT connection to D3 and D4.
When I deconnect those to wire, I'm able to upload the code to the bord but when I reconnect the wire, it still doesn’t work.
Any idea what it can be?
Here's my sketch:
> Source: https://github.com/tangophi/MPU6050_ESP8266_MQTT
> 2023-11-13
>     the default sensitivity range for the accelerometer is +-2g which is equal to 16384*2, in which 16384 LSB is equal to the gravity acceleration 9.81m/s^2
>     in the source code of mpu6050.cpp  line 66 the range has been defined as follows
>     setFullScaleAccelRange(MPU6050_ACCEL_FS_2);
>     by changing the number 2 into 4 the range is also changed into +-4g and the sensitivity accordingly to 8192 lbs.
>     FS_SEL - Register 1B, Bits 3 and 4 (gyroscope sensitivity)
>     Value written to FS_SEL - sensitivity:
>     0 - +-250
>     1 - +-500
>     2 - +-1000
>     3 - +-2000
>     AFS_SEL - Register 1C, Bits 3 and 4 (accelerometer sensitivity)
>     Value written to AFS_SEL - sensitivity:
>     0 - +-2
>     1 - +-4
>     2 - +-8
>     3 - +-16
> I2Cdev device library code is placed under the MIT license
> Copyright (c) 2012 Jeff Rowberg
> Permission is hereby granted, free of charge, to any person obtaining a copy
> of this software and associated documentation files (the "Software"), to deal
> in the Software without restriction, including without limitation the rights
> to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
> copies of the Software, and to permit persons to whom the Software is
> furnished to do so, subject to the following conditions:
> The above copyright notice and this permission notice shall be included in
> all copies or substantial portions of the Software.
> THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
> IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
> FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
> AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
> LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
> OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
> THE SOFTWARE.
> /* This driver reads quaternion data from the MPU6060 and sends
>    Open Sound Control messages.
>   GY-521  NodeMCU
>   MPU6050 devkit 1.0
>   board   Lolin         Description
>   VCC     VU (5V USB)   Not available on all boards so use 3.3V if needed.
>   GND     G             Ground
>   SCL     D1 (GPIO05)   I2C clock
>   SDA     D2 (GPIO04)   I2C data
>   XDA     not connected
>   XCL     not connected
>   AD0     not connected
>   //INT     D8 (GPIO15)   Interrupt pin
>   INT
> //#if defined(ESP8266)
> #include <ESP8266WiFi.h>
> //#else
> //#include <WiFi.h>
> //#endif
> //#include <DNSServer.h>
> #include <WiFiClient.h>
> #include <OSCMessage.h>
> //#include <WiFiManager.h>         //https://github.com/tzapu/WiFiManager
> //#include <PubSubClient.h>
> #include <AsyncMqttClient.h>      //2023-11-11
> #include <Ticker.h>               //2023-11-11
> #include <ArduinoJson.h>
> #include "I2Cdev.h"
> #include <RTClib.h>
> #include "MPU6050_6Axis_MotionApps20.h"
> //#include "MPU6050.h" // not necessary if using MotionApps include file
> // Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
> // is used in I2Cdev.h
> #if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
>     #include "Wire.h"
> #endif
> //I2C device adress
> #define DEVICE_RTC_ADDRESS 0x68           // I2C RTC DEVICE (confirmed with Dev6_I2C_Device_Scanner)
> #define DEVICE_MPU6050_ADDRESS 0x69       // I2C AHT DEVICE when AD0 is set to high (pin D4) (confirmed)
> RTC_DS3231 RTC;
> const char DEVICE_NAME[] = "ESP_MPU";
> const char mqtt_topic_csv[] = "/mpu6050_1/csv";
> const char mqtt_topic_json[] = "/mpu6050_1/json";
> #define WIFI_SSID "My_SSID"
> #define WIFI_PASSWORD "MY_PASSWORD"
> // IP address of your MQTT server
> #define MQTT_HOST IPAddress(111, 111, 11, 11) //Use your ip address
> #define MQTT_PORT 1883
> #define BUFFER_SIZE 200             //was 64
> #define BUFFER_THRESHOLD 48  // 75% of the buffer size - was 48
> char jsonBuffer[BUFFER_SIZE * 50]; // Adjust the size based on your data size
> char csvBuffer[BUFFER_SIZE * 50]; // Adjust the size based on your data size
> unsigned long startTime;
> unsigned long elapsedTime;
> //  /mpu6050_1/csv
> //MQTT Topics           //2023-11-11
> #define MQTT_PUB_MPU6050_CSV "mpu6050_1/csv"
> #define MQTT_PUB_MPU6050_JSON  "mpu6050_1/json"
> unsigned long lastPublishTime_temp = 0;            // Variable to store the last time the MQTT message was published
> AsyncMqttClient mqttClient;
> Ticker mqttReconnectTimer;
> WiFiEventHandler wifiConnectHandler;
> WiFiEventHandler wifiDisconnectHandler;
> Ticker wifiReconnectTimer;
> // Assuming mpu is an instance of MPU6050
> float sensitivity = 16384.0; // Sensitivity for +/- 2g full-scale range
> unsigned long previousMillis = 0;
> const long interval = 5000;
> void connectToWifi() {
>   Serial.println("Connecting to Wi-Fi...");
>   WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
> void onWifiConnect(const WiFiEventStationModeGotIP& event) {
>   Serial.println("Connected to Wi-Fi.");
>   connectToMqtt();
> void onWifiDisconnect(const WiFiEventStationModeDisconnected& event) {
>   Serial.println("Disconnected from Wi-Fi.");
>   mqttReconnectTimer.detach();
>   wifiReconnectTimer.once(2, connectToWifi);
> void connectToMqtt() {
>   Serial.println("Connecting to MQTT...");
>   mqttClient.connect();
> void onMqttConnect(bool sessionPresent) {
>   Serial.println("Connected to MQTT.");
>   Serial.print("Session present: ");
>   Serial.println(sessionPresent);
> void onMqttDisconnect(AsyncMqttClientDisconnectReason reason) {
>   Serial.println("Disconnected from MQTT.");
>   if (WiFi.isConnected()) {
>     mqttReconnectTimer.once(2, connectToMqtt);
> void onMqttPublish(uint16_t packetId) {
>   Serial.print("Publish acknowledged.");
>   Serial.print("  packetId: ");
>   Serial.println(packetId);
> // class default I2C address is 0x68
> // specific I2C addresses may be passed as a parameter here
> // AD0 low = 0x68 (default for SparkFun breakout and InvenSense evaluation board)
> // AD0 high = 0x69
> MPU6050 mpu;
> //MPU6050 mpu(0x69); // <-- use for AD0 high
>    NOTE: In addition to connection 5/3.3v, GND, SDA, and SCL, this sketch
>    depends on the MPU-6050's INT pin being connected to the ESP8266 GPIO15
>    pin.
> // MPU control/status vars
> bool dmpReady = false;  // set true if DMP init was successful
> uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
> uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
> uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
> uint16_t fifoCount;     // count of all bytes currently in FIFO
> uint8_t fifoBuffer[64]; // FIFO storage buffer
> // orientation/motion vars
> Quaternion q;           // [w, x, y, z]         quaternion container
> VectorInt16 aa;         // [x, y, z]            accel sensor measurements
> VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
> VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
> VectorFloat gravity;    // [x, y, z]            gravity vector
> #ifdef OUTPUT_READABLE_EULER
> float euler[3];         // [psi, theta, phi]    Euler angle container
> #endif
> #ifdef OUTPUT_READABLE_YAWPITCHROLL
> float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
> #endif
> // uncomment "OUTPUT_READABLE_QUATERNION" if you want to see the actual
> // quaternion components in a [w, x, y, z] format (not best for parsing
> // on a remote host such as Processing or something though)
> //#define OUTPUT_READABLE_QUATERNION
> // uncomment "OUTPUT_READABLE_EULER" if you want to see Euler angles
> // (in degrees) calculated from the quaternions coming from the FIFO.
> // Note that Euler angles suffer from gimbal lock (for more info, see
> // http://en.wikipedia.org/wiki/Gimbal_lock)
> //#define OUTPUT_READABLE_EULER
> // uncomment "OUTPUT_READABLE_YAWPITCHROLL" if you want to see the yaw/
> // pitch/roll angles (in degrees) calculated from the quaternions coming
> // from the FIFO. Note this also requires gravity vector calculations.
> // Also note that yaw/pitch/roll angles suffer from gimbal lock (for
> // more info, see: http://en.wikipedia.org/wiki/Gimbal_lock)
> //#define OUTPUT_READABLE_YAWPITCHROLL
> // uncomment "OUTPUT_READABLE_REALACCEL" if you want to see acceleration
> // components with gravity removed. This acceleration reference frame is
> // not compensated for orientation, so +X is always +X according to the
> // sensor, just without the effects of gravity. If you want acceleration
> // compensated for orientation, us OUTPUT_READABLE_WORLDACCEL instead.
> #define OUTPUT_READABLE_REALACCEL
> // uncomment "OUTPUT_READABLE_WORLDACCEL" if you want to see acceleration
> // components with gravity removed and adjusted for the world frame of
> // reference (yaw is relative to initial orientation, since no magnetometer
> // is present in this case). Could be quite handy in some cases.
> //#define OUTPUT_READABLE_WORLDACCEL
> // uncomment "OUTPUT_TEAPOT_OSC" if you want output that matches the
> // format used for the InvenSense teapot demo
> //#define OUTPUT_TEAPOT_OSC
> //#define INTERRUPT_PIN 15 // use pin 15 on ESP8266
> #define INTERRUPT_PIN 0 // use pin D3 on ESP8266
> #define AD0_PIN 16  // use pin D4 on ESP8266
> //const int AD0_PIN = D4;  // use pin D4 on ESP8266
> // ===               INTERRUPT DETECTION ROUTINE                ===
> volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
> void dmpDataReady() {
>     mpuInterrupt = true;
> // 2023-10-30
> void ICACHE_RAM_ATTR dmpDataReady() {
> bool mpu_setup()
>   // join I2C bus (I2Cdev library doesn't do this automatically)
>   // ... (existing code)
>   // initialize device
>   Serial.println(F("Initializing I2C devices..."));
>   if (!mpu.initialize()) {
>     Serial.println(F("MPU6050 connection failed"));
>     return false;
>   // verify connection
>   Serial.println(F("Testing device connections..."));
>   if (!mpu.testConnection()) {
>     return false;
>   //To change AD0 to high on MPU6050 from 0x68 to 0x69
>   pinMode(AD0_PIN, OUTPUT);    // sets the digital pin D7 as output
>   // I2C Communication with MPU6050
>   Wire.beginTransmission(DEVICE_MPU6050_ADDRESS);
>   Wire.begin();
>   Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
> #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
>   Fastwire::setup(400, true);
> #endif
>   mpu.initialize();
>   pinMode(INTERRUPT_PIN, INPUT);
>   Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
>   // load and configure the DMP
>   Serial.println(F("Initializing DMP..."));
>   devStatus = mpu.dmpInitialize();
>   // 2023-10-30: Calibration values found with MPU6050_calibration_Wemos_2023_10_31.ino
>   // supply your own gyro offsets here, scaled for min sensitivity
>   mpu.setXGyroOffset(97);
>   mpu.setYGyroOffset(-58);
>   mpu.setZGyroOffset(-2);
>   mpu.setXAccelOffset(556);
>   mpu.setYAccelOffset(-974);
>   mpu.setZAccelOffset(1503);
>   // make sure it worked (returns 0 if so)
>   if (devStatus == 0) {
>     // turn on the DMP, now that it's ready
>     Serial.println(F("Enabling DMP..."));
>     mpu.setDMPEnabled(true);
>     // enable Arduino interrupt detection
>     Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
>     attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
>     mpuIntStatus = mpu.getIntStatus();
>     // set our DMP Ready flag so the main loop() function knows it's okay to use it
>     Serial.println(F("DMP ready! Waiting for first interrupt..."));
>     dmpReady = true;
>     // get expected DMP packet size for later comparison
>     packetSize = mpu.dmpGetFIFOPacketSize();
>     Serial.print("packetSize: ");
>     Serial.println(packetSize);
>   } else {
>     // ERROR!
>     // 1 = initial memory load failed
>     // 2 = DMP configuration updates failed
>     // (if it's going to break, usually the code will be 1)
>     Serial.print(F("DMP Initialization failed (code "));
>     Serial.print(devStatus);
>     Serial.println(F(")"));
>   return true; // MPU6050 initialization successful
>   Wire.endTransmission();
> void mpu_loop()
>   static char buf[50];
>   static ArduinoJson::StaticJsonDocument<300> jsonDoc;
>   static JsonObject root = jsonDoc.to<JsonObject>();
>   static uint8_t bufferIndex = 0;
>   // I2C Communication with RTC
>   Wire.beginTransmission(DEVICE_RTC_ADDRESS);
>     DateTime now = RTC.now();
>     uint32_t timestamp = now.unixtime();
>     // Get the current time in hours and minutes
>     //float currentTime = now.hour() + (now.minute() / 60.0);
>   if (!dmpReady) return;
>   if (!mpuInterrupt && fifoCount < packetSize) return;
>   fifoCount = mpu.getFIFOCount();
>   if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
>     mpu.resetFIFO();
>     Serial.println(F("FIFO overflow!"));
>   } else if (mpuIntStatus & 0x02) {
>     while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
>     mpu.getFIFOBytes(fifoBuffer, packetSize);
>     fifoCount -= packetSize;
>   // end of addition
> #ifdef OUTPUT_READABLE_QUATERNION
>     // display quaternion values in easy matrix form: w x y z
>     mpu.dmpGetQuaternion(&q, fifoBuffer);
>     Serial.print("quat\t");
>     Serial.print(q.w);
>     Serial.print("\t");
>     Serial.print(q.x);
>     Serial.print("\t");
>     Serial.print(q.y);
>     Serial.print("\t");
>     Serial.println(q.z);
> #endif
> #ifdef OUTPUT_TEAPOT_OSC
> #ifndef OUTPUT_READABLE_QUATERNION
> #endif
>     // Send OSC message
>     OSCMessage msg("/imuquat");
>     msg.add((float)q.w);
>     msg.add((float)q.x);
>     msg.add((float)q.y);
>     msg.add((float)q.z);
>     msg.empty();
> #endif
>     // display Euler angles in degrees
>     mpu.dmpGetEuler(euler, &q);
>     Serial.print("euler\t");
>     Serial.print(euler[0] * 180/M_PI);
>     Serial.print("\t");
>     Serial.print(euler[1] * 180/M_PI);
>     Serial.print("\t");
>     Serial.println(euler[2] * 180/M_PI);
> #endif
>     mpu.dmpGetGravity(&gravity, &q);
>     mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
>     Serial.print("ypr\t");
>     Serial.print(ypr[0] * 180/M_PI);
>     Serial.print("\t");
>     Serial.print(ypr[1] * 180/M_PI);
>     Serial.print("\t");
>     Serial.println(ypr[2] * 180/M_PI);
> #endif
> #ifdef OUTPUT_READABLE_REALACCEL
>     // display real acceleration, adjusted to remove gravity
>     mpu.dmpGetAccel(&aa, fifoBuffer);
>     mpu.dmpGetLinearAccel(&aaReal, &aa, &gravity);
>     //Serial.print("areal\t");
>     Serial.print(elapsedTime);
>     Serial.print("\t");
>     Serial.print(aaReal.x);
>     Serial.print("\t");
>     Serial.print(aaReal.y);
>     Serial.print("\t");
>     Serial.println(aaReal.z);
>     // Update JSON document with new sensor data
>     jsonDoc["timestamp"] = elapsedTime;
>     jsonDoc["X"] = aaReal.x;
>     jsonDoc["Y"] = aaReal.y;
>     jsonDoc["Z"] = aaReal.z;
>     // 2023-11-12 addition from chatgpt
>     // Serialize JSON document to a string and add it to the buffer
>     serializeJson(jsonDoc, buf);
>     strcat(jsonBuffer, buf);
>     strcat(jsonBuffer, "\n");  // Add newline for better separation
>     // Add CSV data to the buffer
>     //sprintf(buf, "%lu,%d,%d,%d\n", elapsedTime, aaReal.x, aaReal.y, aaReal.z);
>     //strcat(csvBuffer, buf);
>     // Format the sensor data as a CSV string and store it in the 'buf' variable
>     //sprintf(buf, "%lu,%d,%d,%d", elapsedTime, aaReal.x, aaReal.y, aaReal.z);
>     //sprintf(buf, "sensor_data timestamp=%lu,x=%d,y=%d,z=%d", elapsedTime, aaReal.x, aaReal.y, aaReal.z);
>     //sprintf(buf, "%lu,%d,%d,%d\n", elapsedTime, aaReal.x, aaReal.y, aaReal.z);  //Si pas de RTC
>     sprintf(buf, "%lu,%d,%d,%d\n", timestamp, aaReal.x, aaReal.y, aaReal.z);    //Avec timestamp RTC
>     // Explanation:
>     // - %lu: Format specifier for an unsigned long integer (elapsedTime is an unsigned long)
>     // - %d: Format specifier for a signed decimal integer (aaReal.x, aaReal.y, aaReal.z are integers)
>     // - ,: Separator (comma in this case, as it's a CSV format)
>     // - elapsedTime: The timestamp of the sensor data
>     // - aaReal.x, aaReal.y, aaReal.z: Acceleration values along the X, Y, and Z axes
>     // Add a newline character at the end
>     //strcat(buf, "\n");
> #endif
> #ifdef OUTPUT_READABLE_WORLDACCEL
>     // display initial world-frame acceleration, adjusted to remove gravity
>     // and rotated based on known orientation from quaternion
>     mpu.dmpGetLinearAccelInWorld(&aaWorld, &aaReal, &q);
>     Serial.print("aworld\t");
>     Serial.print(aaWorld.x);
>     Serial.print("\t");
>     Serial.print(aaWorld.y);
>     Serial.print("\t");
>     Serial.println(aaWorld.z);
>     #endif
>     bufferIndex++;
>     unsigned long currentTime = millis();
>     // Calculate the elapsed time since the start
>     //elapsedTime = currentTime - startTime;
>     // Check if the buffer is 75% full
>     if (bufferIndex >= BUFFER_THRESHOLD) {
>         // Add timestamp to the JSON message
>         //jsonDoc["Timestamp"] = elapsedTime;
>         //serializeJson(jsonDoc, buf);
>         //strcat(jsonBuffer, buf);
>         //strcat(jsonBuffer, "\n");
>         // Format the linear acceleration data as a comma-separated string
>         //snprintf(buf, sizeof(buf), "%d,%d,%d,%d", elapsedTime, aaReal.x, aaReal.y, aaReal.z);
>         // Publish an MQTT CSV message
>         uint16_t packetIdPub1 = mqttClient.publish(mqtt_topic_csv, 1, true, csvBuffer);      // 2023-11-12  buf était csvBuffer
>         Serial.printf("Publishing on topic %s at QoS 1, packetId %i: ", mqtt_topic_csv, packetIdPub1);
>         Serial.printf("Message: %s \n", csvBuffer);
>         // Publish an MQTT json message
>         //uint16_t packetIdPub2 = mqttClient.publish(mqtt_topic_json, 1, true, buf);
>         //Serial.printf("Publishing on topic %s at QoS 1, packetId %i: ", mqtt_topic_json, packetIdPub2);
>         //Serial.printf("Message: %s \n", buf); // Use %s for string data
>         // Reset the buffer and index
>         //jsonBuffer[0] = '\0';
>         //buf[0] = '\0';
>         csvBuffer[0] = '\0';
>         bufferIndex = 0;
>         // Update the start time (uncomment to restart timestamp for every csv batch)
>         //startTime = millis();
>   Wire.endTransmission();     //MPU6050
> void setup(void)
>   Serial.begin(115200);
>   Serial.println(F("\nOrientation Sensor OSC output")); Serial.println();
>   wifiConnectHandler = WiFi.onStationModeGotIP(onWifiConnect);
>   wifiDisconnectHandler = WiFi.onStationModeDisconnected(onWifiDisconnect);
>   mqttClient.onConnect(onMqttConnect);
>   mqttClient.onDisconnect(onMqttDisconnect);
>   mqttClient.onPublish(onMqttPublish);
>   mqttClient.setServer(MQTT_HOST, MQTT_PORT);
>   connectToWifi();
>   Serial.print(F("WiFi connected! IP address: "));
>   Serial.println(WiFi.localIP());
>   //RTC.begin();
>    if (! RTC.begin()) {
>     Serial.println("Couldn't find RTC");
>     Serial.flush();
>     while (1) delay(10);
>   if (RTC.lostPower()) {
>     Serial.println("RTC lost power, let's set the time!");
>     // When time needs to be set on a new device, or after a power loss, the
>     // following line sets the RTC to the date & time this sketch was compiled
>     //rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
>         // This line sets the RTC with an explicit date & time, for example to set
>     // January 21, 2014 at 3am you would call:
>     // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
>      RTC.adjust(DateTime(2023, 11, 27, 22, 43, 0));
>   // When time needs to be re-set on a previously configured device, the
>   // rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
>   // RTC.adjust(DateTime(2023, 07, 22, 1, 34, 0));
>   // Check if the RTC module has been initialized
>   if (!RTC.now().isValid()) {
>     // Set the current date and time here if needed
>     //RTC.adjust(DateTime(F(__DATE__), F(__Time__)));
>     RTC.adjust(DateTime(2023, 7, 18, 20, 7, 0));
>   // Retry MPU6050 initialization up to 5 times
>     int maxRetries = 5;
>     int retryCount = 0;
>     while (!mpu_setup() && retryCount < maxRetries) {
>         Serial.println(F("Retrying MPU6050 initialization in 5 seconds..."));
>         delay(5000); // Wait for 5 seconds before retrying
>         retryCount++;
>     if (retryCount == maxRetries) {
>         Serial.println(F("MPU6050 initialization failed after maximum retries. Check your connections."));
>         // You might want to handle this situation, e.g., by entering a safe state or rebooting.
>         // For now, the program will continue, and you might get unexpected behavior.
>     // Initialize start time
> void loop(void)
>   if (WiFi.status() != WL_CONNECTED) {
>     Serial.println();
>     Serial.println("*** Disconnected from AP so rebooting ***");
>     Serial.println();
>     ESP.reset();
>     mpu.resetFIFO();
>   if (!mqttClient.connected()) {
>     //reconnect();
>     mpu.resetFIFO();
>   mpu_loop();
>   delay(20);
>   mpu.resetFIFO();
you don't need AD0 and INT for the MPU6050. AD0 sets the address, so this is static anyway, and it is connected to GND or VCC --> this most likely causes the trouble
Thanks for the comments! I'm looking in the spec sheet and I'm not sure I understand if I can connect AD0 to 3.3V
I will try it tomorow night. Unfortunately, I don't have access today.
You can leave AD0 unconnected, same goes for INT - that is, if our code does not explictly need INT.
Also note that ICACHE_RAM_ATTR is now called IRAM_ATTR - might be that that change causes your program to crash when INT goes high. Reference — ESP8266 Arduino Core 3.1.2-21-ga348833 documentation
I2C MPU6050 ant RTC are using the same adress (0x68)
AD0 change the sdress of MPU6050 to 0x69; is needed in my case to use timestamp from RTC.
I will have a look at ICACHE_RAM_ATTR vs IRAM_ATTR. (not a simple subject for my level of understanding)
Please fix your post! Post code according to the forum guide by using code tags!
just change ICACHE_RAM_ATTR to IRAM_ATTR, then your current setup should work.
I did change ICACHE_RAM_ATTR to IRAM_ATTR.
I did scan both I2C address and I can see both address.
Scanning...
I2C device found at address 0x68 !
I2C device found at address 0x69 !
I did use a pull up resistor on both I2C wire to MPU6050
I'm still having those message:
WiFi connected! IP address: (IP unset)
Initializing DMP...
DMP Initialization failed (code 1)
Connected to Wi-Fi.
Connected to MQTT.
Session present: 0
Not sure what to look for now.
Any idea?
This is the part you need to change. Please try to figure it out.
Also please try to fix how you posted your code. It is inside code tags now, which is good, but every line of your code seems to start with ">", which would prevent it from getting compiled and uploaded.
