Wemos D1 EEProm put/get not getting correct value
Hey all I have the following code in my Arduino IDE:
#include <EEPROM.h>
#include <ArduinoJson.h>
bool debuggin         = true;
int brightness        = 255;
int ambientLight      = 30;
struct RGBLA {
  uint8_t R;
  uint8_t G;
  uint8_t B;
  uint8_t L;
  uint8_t A;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  EEPROM.begin(512);
  readSavedSettings();
  updateEEProm(255,255,255,200,35,true,false);
RGBLA readEEProm() {
  int addr = 0;
  RGBLA customVars;
  EEPROM.get(addr, customVars);
  return customVars;
void readSavedSettings() {
  RGBLA returnedVars = readEEProm();
  if (debuggin) { Serial.println("START readSavedSettings"); }
  if (returnedVars.A == 00 || returnedVars.A == 0) {
    if (debuggin) { Serial.println("'A' not found! Default 30"); }
    ambientLight = returnedVars.A;
    if (debuggin) {
      Serial.print("'A' found! ");
      Serial.println(ambientLight);
  for(uint8_t i = 0; i < 3/*strip.numPixels()*/; i++) {
    if (debuggin) {
      Serial.print("LED ");
      Serial.print(i);
      Serial.print(" set to: R: ");
      Serial.print((uint8_t)returnedVars.R);
      Serial.print(", G: ");
      Serial.print((uint8_t)returnedVars.G);
      Serial.print(", B: ");
      Serial.println((uint8_t)returnedVars.B);
  if (debuggin) {
    Serial.println("Turned off RGB LEDS");
    Serial.println("END readSavedSettings");
void updateEEProm(uint8_t R,
                  uint8_t G,
                  uint8_t B,
                  uint8_t L,
                  uint8_t A,
                  bool saveRGBL,
                  bool saveA) {
  int addr = 0;
  RGBLA customVars;
  //Save old json before clearing EEProm
  //Clear EEProm
  for (unsigned int i = 0; i < EEPROM.length(); i++) {
    EEPROM.write(i, 0);
  if (saveRGBL) {
    //Get A value so that we can save it the same value
    DynamicJsonBuffer jsonBuffer(JSON_OBJECT_SIZE(5));
    JsonObject& root = jsonBuffer.createObject();
    if (debuggin) {
      Serial.print("Old JSON:");
      Serial.print(" R: ");
      Serial.print((uint8_t)customVars.R);
      Serial.print(" G: ");
      Serial.print((uint8_t)customVars.G);
      Serial.print(" B: ");
      Serial.print((uint8_t)customVars.B);
      Serial.print(" L: ");
      Serial.print((uint8_t)customVars.L);
      Serial.print(" A: ");
      Serial.println((uint8_t)customVars.A);
    root["R"] = (uint8_t)R;
    root["G"] = (uint8_t)G;
    root["B"] = (uint8_t)B;
    root["L"] = (uint8_t)L;
    root["A"] = (uint8_t)customVars.A;
    if (debuggin) {
      Serial.print("New JSON:");
      Serial.print((uint8_t)root["R"]);
      Serial.print((uint8_t)root["G"]);
      Serial.print((uint8_t)root["B"]);
      Serial.print((uint8_t)root["L"]);
      Serial.println((uint8_t)root["A"]);
    EEPROM.put(addr, root);
  if (saveA) {
    //Get R,G,B,L values so that we can save it the same value
    if (debuggin) {
    root["R"] = (uint8_t)customVars.R;
    root["G"] = (uint8_t)customVars.G;
    root["B"] = (uint8_t)customVars.B;
    root["L"] = (uint8_t)customVars.L;
    root["A"] = (uint8_t)A;
    if (debuggin) {
And this is the output of that code:
'A' found! 96
LED 0 set to: R: 48, G: 255, B: 255
LED 1 set to: R: 48, G: 255, B: 255
LED 2 set to: R: 48, G: 255, B: 255
Turned off RGB LEDS
Old JSON: R: 48   G: 255 B: 255 L: 63   A: 96
New JSON: R: 255  G: 255 B: 255 L: 200  A: 96
Old JSON: R: 48   G: 255 B: 255 L: 63   A: 160
New JSON: R: 48   G: 255 B: 255 L: 63   A: 35
Now when I reset it this is the output:
⸮dOX⸮,R⸮X⸮4xC⸮⸮⸮START readSavedSettings
'A' found! 96
Turned off RGB LEDS
How come the Old JSON has the 'L' value as 63 again when it should be the New JSON value of 200? Why did it not save it but saved all the others? Also, Why is 'R' 48 when it should be 255 like G and B?
Is there something wrong in my code?
The ESP8266's EEPROM library works a little bit differently than the regular Arduino EEPROM library. This is because the ESP8266 doesn't actually have EEPROM so they use flash memory to emulate EEPROM.
The difference is that when you use EEPROM.put() or EEPROM.write() the data isn't actually written to flash memory, it's only stored in volatile memory that will be lost when you reset the ESP8266. The data is only written to the non-volatile flash memory when you call EEPROM.commit() or EEPROM.end(). This is done so that you don't quickly wear out the flash. Flash memory must be written one page at a time, rather than EEPROM which is written a one-byte cell at a time. So it would be quite inefficient to write an entire page of flash every time the ESP8266's "EEPROM" data is changed.
For more information, see the ESP8266 core for Arduino's documentation:
https://arduino-esp8266.readthedocs.io/en/latest/libraries.html#eeprom
Hum, even doing
EEPROM.commit();
updateEEProm(255,255,255,200,35,false,true);
EEPROM.commit();
Still does not seem to save it?
This is the output after adding .end() to it:
'A' found! 160
Turned off RGB LEDS
New JSON: R: 255  G: 255  B: 255  L: 200 A: 160
Old JSON: R: 128  G: 12   B: 17   L: 17 A: 60
New JSON: R: 128  G: 12   B: 17   L: 17 A: 35
and the code i use:
  // initialize serial and wait for port to open:
  while (!Serial) {
  EEPROM.begin(512);
  updateEEProm(255,255,255,200,35,true,false); //Save all but 'A' value
  EEPROM.end();
  updateEEProm(255,255,255,200,35,false,true); //Save just 'A' value
  EEPROM.end();
a second problem is with the JSON conversion. you should reduce the example to the part where the error occurs
