I have uploaded a sketch which works on another board, same make and release. (V2015-08).
It compiles ok and appears to upload with no errors. However there is no serial output and I think the program is not running on the board.
Here is the compile and upload log:
Sketch uses 331909 bytes (31%) of program storage space. Maximum is 1044464 bytes.
Global variables use 30280 bytes (36%) of dynamic memory, leaving 51640 bytes for local variables. Maximum is 81920 bytes.
C:\Users\rich.KG.000\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3 -I C:\Users\rich.KG.000\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py --chip esp8266 --port COM3 --baud 921600 --before default_reset --after hard_reset write_flash 0x0 C:\Users\RICHKG~1.000\AppData\Local\Temp\arduino_build_593555/web02.ino.bin
esptool.py v3.0
Serial port COM3
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: dc:4f:22:54:c1:cf
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 336064 bytes to 242505...
Writing at 0x00000000... (6 %)
Writing at 0x00004000... (13 %)
Writing at 0x00008000... (20 %)
Writing at 0x0000c000... (26 %)
Writing at 0x00010000... (33 %)
Writing at 0x00014000... (40 %)
Writing at 0x00018000... (46 %)
Writing at 0x0001c000... (53 %)
Writing at 0x00020000... (60 %)
Writing at 0x00024000... (66 %)
Writing at 0x00028000... (73 %)
Writing at 0x0002c000... (80 %)
Writing at 0x00030000... (86 %)
Writing at 0x00034000... (93 %)
Writing at 0x00038000... (100 %)
Wrote 336064 bytes (242505 compressed) at 0x00000000 in 5.5 seconds (effective 489.0 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
Here is the sketch: (I have blanked out username and password for network)
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <time.h>
#define UTC_OFFSET +1
const char *ssid = "";
const char *password = "";
int sensorValue = 0;
float volts = 0;
float cel = 0;
long temphist[40];
int t = 0;
char cIP[50];
IPAddress arduino_ip (192, 168, 1, 45);
IPAddress dns_ip ( 192, 168, 1, 121);
IPAddress dns_ip_2 ( 8, 8, 8, 8);
IPAddress gateway_ip ( 192, 168, 1, 1);
IPAddress subnet_mask(255, 255, 255, 0);
char sTime [50];
ESP8266WebServer server ( 8182 );
const int led = 13;
void handleRoot() {
digitalWrite ( led, 1 );
char temp[450];
int sec = millis() / 1000;
int min = sec / 60;
int hr = min / 60;
sensorValue = analogRead(A0);
volts = (sensorValue / 1023.0) * 5000;
cel = volts * 0.1;
//long nTemp = long(cel) -13; // fudge, as esp gets it wrong
long nTemp = long(cel) - 6; // should be correct
temphist[t] = nTemp;
t++;
if (t > 39) {
t = 0;
snprintf ( temp, 450,
"<html>\
<head>\
<meta http-equiv='refresh' content='10'/>\
<title>ESP8266 Demo</title>\
<style>\
body { background-color: #cccccc; font-family: Arial, Helvetica, Sans-Serif; Color: #000088; }\
</style>\
</head>\
<body>\
<h1>Richard's ESP8266 temperature monitor</h1>\
<p>on ip: %s</p>\
<p><b>Temp degC: %d at %s</b></p>\
<p><img src=\"/test.svg\" /></p>\
</body>\
</html>",
cIP, nTemp, sTime
server.send ( 200, "text/html", temp );
digitalWrite ( led, 0 );
void handleNotFound() {
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += ( server.method() == HTTP_GET ) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for ( uint8_t i = 0; i < server.args(); i++ ) {
message += " " + server.argName ( i ) + ": " + server.arg ( i ) + "\n";
server.send ( 404, "text/plain", message );
void setup ( void ) {
pinMode ( led, OUTPUT );
Serial.begin ( 115200 );
WiFi.mode ( WIFI_STA );
WiFi.config(arduino_ip, gateway_ip, subnet_mask);
// WiFi.setDNS(dns_ip); // not supported
WiFi.begin ( ssid, password );
Serial.println ( "" );
// Wait for connection
while ( WiFi.status() != WL_CONNECTED ) {
delay ( 500 );
Serial.print ( "." );
Serial.print ( "Connected to " );
Serial.println ( ssid );
Serial.print ( "IP address: " );
Serial.println ( WiFi.localIP() );
String sIP = WiFi.localIP().toString();
int cc= 0;
for (cc = 0; cc<sIP.length(); cc++)
cIP[cc] = sIP[cc];
cIP[cc] = 0;
if ( MDNS.begin ( "esp8266" ) ) {
Serial.println ( "MDNS responder started" );
configTime(UTC_OFFSET * 3600, 0,"216.239.35.4", "uk.pool.ntp.org", "1.europe.pool.ntp.org"); // first one is time.google.com
Serial.println("\nWaiting for time");
while (!time(nullptr)) {
Serial.print("t");
Serial.println("");
server.on ( "/", handleRoot );
server.on ( "/test.svg", drawGraph );
server.on ( "/inline", []() {
server.send ( 200, "text/plain", "this works as well" );
server.onNotFound ( handleNotFound );
server.begin();
Serial.println ( "HTTP server started" );
cel = volts * 0.1;
Serial.print("temp = ");
Serial.println(cel);
void loop ( void ) {
time_t now = time(nullptr);
// Serial.println(ctime(&now));
sprintf(sTime, ctime(&now)); // incorrect time
server.handleClient();
void drawGraph() {
String out = "";
char temp[100];
out += "<svg xmlns=\"http://www.w3.org/2000/svg\" version=\"1.1\" width=\"400\" height=\"150\">\n";
out += "<rect width=\"400\" height=\"150\" fill=\"rgb(250, 230, 210)\" stroke-width=\"1\" stroke=\"rgb(0, 0, 0)\" />\n";
out += "<g stroke=\"red\">\n";
int y = temphist[0];
int x1 = 0;
for (int x = 10; x < 390; x+= 10) {
if (x1 < (t-1))
y = temphist[x1];
int y2 = temphist[x1+1];
sprintf(temp, "<line x1=\"%d\" y1=\"%d\" x2=\"%d\" y2=\"%d\" stroke-width=\"2\" />\n", x, 120 - y, x + 10, 120 - y2);
out += temp;
x1++;
out += "</g>\n</svg>\n";
server.send ( 200, "image/svg+xml", out);
