You still should get rid of the print in the ISR though
Also as there is actually not a lot left in IRAM, it’s always worth thinking twice at what you add there. Does your PIR requires an interrupt or can you just check it from time to time in the loop?
That was just a short example I wrote for debugging purpose.
The real procedure just increments a counter!
About "requiring an interrupt" I asked this question myself many times... :LOL:
I'm pretty new to electronics (I'm a computer programmer) and I assumed that the less "useless" code I run into loop function, the better will be the response expecially if the loop not only check the sensors (they are two) but also have to check wifi state, send "alive pings" to server and some other stuffs. Considering I have to debounce the signals coming from the other sensor etc., I suppose that avoid to run code when it's not needed is the best solution. I always have the fear that I'm not running an intel i7 under the table... it's just a weMos
sure - but checking the status of 2 pins takes only a few micro-seconds → that won’t kill your performance even if it’s just a WeMos (compared to wifi latency and other operations)
I’m sure you check in the main loop() the value of your counter → so you do execute a test anyway each time you run the loop.
J-M-L:
sure - but checking the status of 2 pins takes only a few micro-seconds --> that won't kill your performance even if it's just a WeMos (compared to wifi latency and other operations)
I'm sure you check in the main loop() the value of your counter --> so you do execute a test anyway each time you run the loop.
with Arduino style network libraries it is hard to have a 'realtime' loop. it is much simpler to use the interrupt for a sensor which send a short pulse
J-M-L:
Getting deeper into the logic I'm using, I need to debounce multiple "ticks" of the sensor to avoid false positive (not the PIR sensor, but a window damper sensor) but I start the "test procedure" only if the FIRST tick happens. that's why I preferred to use the interrupt, because I avoid to execute millis counting, testing differences, 5 millis intervals for debounce, etc. I do that only if really necessary!
Of course there are multiple ways to solve a problem depending the personal point of view and mine could be not the best one. Maybe it's unnecessary to use the interrupts but I came into this path after I valued many possible solutions. Maybe in the future I realize there is a better one for some reason and I'll change it
OK - whatever rocks your boat and get you what you need is cool
indeed multiple ways to do something. I tend to avoid ISR as much as I can as they usually bring complexity with things changing behind your back that you need to worry about and create protected sections etc.
Juraj:
Yes - my point was for this case as a PIR usually gets activated and stays ON for a while (seconds or minutes) --> hence the question around the need for using interrupts esp. as the handling of the detection would still happen in the loop anyway given it only triggers a counter. Short pulses you might miss are indeed a different story.
but I'm fine with all approaches, was just my personal view.
J-M-L:
Absolutely RIGHT! In fact when I realized that the timeout in the PIR sensor is so long (too long!!!) I switched for the loop check for it.
Consider it's my really first time with a Arduino style project and while i discover things (and tricks) i change things on the way.
Every suggestion is well accepted since they create experience!
Maschiaccio72:
most PIR have 2 small potentiometers - one that let you set the sensitivity for a trigger, and one that lets you set the duration of the activation once an event is detected. turn it to the minimum and you'll get a few seconds (usually ~5s - which is still long in some cases)
