WEMOS D1 MINI + DHT12 I2C
Hello
I'm trying to get my Wemos D1 min working with my DHT12 Shield but I've got some difficulties.
As seen in the picture, Wemos D1 mini and the shield are soldered on 4 pins :
  • 3V3
  • GND
  • D1
  • D2
I have tried to use the Wemos DHT12 library and these librairies :
The problem that I'm facing is that I don't manage to read my sensor and to configure I2C adress
Does anyone know how to make it work ?
Thx
This is my code :
  • Example for a DHT12 sensor
  • Beware some of the diagrams about the pinouts are incorrect.
  • Pin Definition 1.VDD 2.SDA 3.GND 4.SCL
  • Look at the sensor one side has holes to allow air inside.
  • Let's call the surface with holes the FRONT.
  • The BACK of the sensor has printed codes and no holes.
  • The 4 PINS for connection come out of the BOTTOM of the sensor.
  • OK so we have defined the orientation of the sensor.
  • Looking at the FRONT of the Sensor with the legs pointing down
  • the LEFTMOST PIN is PIN ONE
  • ! O O O O O !
  • ! O O O O O !
  • ! O O O O O !
  • ! O O O O O !
  • 1 2 3 4
#include <Wire.h>
#include <dht.h>
dht12 DHT(0x5c); ==> That's where I'm Stuck . Changing it to D1 or D2 is not working anymore.
Serial.println(F("DHT12 TEST PROGRAM"));
unsigned long b = micros();
dht::ReadStatus chk = DHT.read();
unsigned long e = micros();
Serial.print(F("Read sensor: "));
switch (chk)
case dht::ok:
Serial.print(F("OK, took "));
Serial.print (e - b); Serial.print(F(" usec, "));
case dht::ERROR_CHECKSUM:
Serial.println(F("Checksum error"));
case dht::ERROR_TIMEOUT:
Serial.println(F("Timeout error"));
case dht::ERROR_CONNECT:
Serial.println(F("Connect error"));
case dht::ERROR_ACK_L:
Serial.println(F("AckL error"));
case dht::ERROR_ACK_H:
Serial.println(F("AckH error"));
default:
Serial.println(F("Unknown error"));
Serial.print(F("Humidity: "));
Serial.print((float)DHT.getHumidity()/(float)10);
Serial.print(F("%, "));
Serial.print(F(". Temperature (degrees C): "));
Serial.print((float)DHT.getTemperature()/(float)10);
Serial.print(F(", Dew Point (degrees C): "));
Serial.println(DHT.dewPoint());
delay(4000);
// END OF FILE
