Wemos D1 Mini - integrated LDO - 4x AA battery?
Hi, started fiddling with arduinos just a month or two ago. I come from a programming background but am totally clueless about electronics (can't read schematics, don't know how stuff works), so please bear with me.
I'm looking for the easiest way to power a Wemos D1 Mini using batteries. I don't want to play with LiPos since I don't want to take a fire hazzard risk. I (presumably) don't want 18650 because I don't know how I would charge it. So the easiest, safest and most convenient seems to use AA batteries. The board will be in deep sleep for weeks at a time and when fired, it will log in wifi, send a http request and go back to sleep.
Now, I've come across this reply (esp8266 - Power D1 mini with 4 AA batteries - Electrical Engineering Stack Exchange) which says that the 5v input goes to a 3v3 LDO and that I can use 4 AA batteries without a need for any other parts (ie LDO).
Could someone please check if that is the case? The schematic from the site I bought the ESP from is here (https://www.laskakit.cz/user/related_files/wemos_d1_mini_schematic.pdf).
Also, I assume it would be fine to have a battery box. But what do I do with the wires? Solder one to the 5V pin and one to ground? Can I have more wires connected to the ground? I'm going to be using a reed sensor where one wire goes to a GPIO pin and one to the ground.
Any other things I should be aware of?
Thanks!
Well, the only problems with using a 6 V alkaline battery (4 x "AA", can be 6.4 V with fresh batteries) are that the battery voltage is very close to the maximum rating of the CH340 chip and that even when not connected to USB, it does draw a small fraction of a milliamp (nominal 150 µA).
Apart from that, it should be fine. :grin:
TP4056
https://www.aliexpress.com/item/32971096125.html
If you do not need 5 volts (for USB2TTL chip or other peripherals) you can try with only 2 batteries - from the data sheet of ESP8266 'Operating Voltage 2.5 V ~ 3.6 V'.
