Hello Coders,
I am trying to do a small project with SIM800L with Wemos d1 mini. It is a DTMF based project. The problem here is, every time I make a call the d1 mini is getting reset. This is my first project with d1 mini. For the past few days I have googled, trying to find a solution. But I failed. I will be very grateful if you can provide the solution.
I am getting these errors in the serial monitor:
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v00043b40
~ld
I am using Arduino IDE. Version: 1.8.8
Here is my project code.
#include <SoftwareSerial.h>
#define rxPin D3
#define txPin D4
SoftwareSerial sim800L(rxPin, txPin);
#define RELAY_1 D7
#define RELAY_2 D8
boolean relay1_state = false;
boolean relay2_state = false;
//stores incomming data from sim800l
String buff;
String dtmf_cmd;
boolean is_call = false;
String ownerNumber = "xxxxxxxxxxxxxxx";
pinMode(RELAY_1, OUTPUT);
pinMode(RELAY_2, OUTPUT);
//Begin serial communication with (Serial Monitor)
//Begin serial communication with (SIM800L)
sim800L.begin(9600);
Serial.println("Begin serial communication with (SIM800L)");
sim800L.println("AT"); //send AT
sim800L.println("AT+DDET=1"); //Enable DTMF
sim800L.println("AT+CLIP=1"); // Enable CallerID
while (sim800L.available()) {
buff = sim800L.readString();
Serial.println("Raw: " + buff);
if (is_call == true) {
if (int index = buff.indexOf("+DTMF:") > -1 ) {
index = buff.indexOf(":");
dtmf_cmd = buff.substring(index + 1, buff.length());
dtmf_cmd.trim();
Serial.println("dtmf_cmd: " + dtmf_cmd);
doAction();
if (buff.indexOf("NO CARRIER") > -1) {
sim800L.println("ATH");
is_call = false;
if (buff.indexOf("RING") > -1) {
// Now check the caller number
if (buff.indexOf("+CLIP:")) {
unsigned int index, index1;
index = buff.indexOf("\"");
index1 = buff.indexOf("\"", index + 1);
String temp = buff.substring(index + 2, index1);
temp.trim();
if (ownerNumber == "+" + temp) {
Serial.println("Number matched");
delay(2000);
sim800L.println("ATA");
is_call = true;
Serial.println("Number not matched");
while (Serial.available()) {
sim800L.println(Serial.readString());
void doAction() {
if (dtmf_cmd == "1") {
relay1_state = !relay1_state;
digitalWrite(RELAY_1, relay1_state);
if (relay1_state == true)
Serial.println("Relay 1 has been ON");
Serial.println("Relay 1 has been OFF");
else if (dtmf_cmd == "2") {
relay2_state = !relay2_state;
digitalWrite(RELAY_2, relay2_state);
if (relay2_state == true)
Serial.println("Relay 2 has been ON");
Serial.println("Relay 2 has been OFF");
