Wemos D1 mini, Max7219, Bitcoin ALarm
Werte Gemeinde, ich nutze einen Wemos d1 mini und ein 32x8 Max 7219 8x8 Display für den folgenden Sketch
#include <Arduino.h>
#include <ArduinoJson.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
const uint16_t WAIT_TIME = 1000;
// Define the number of devices we have in the chain and the hardware interface
// NOTE: These pin numbers will probably not work with your hardware and may
// need to be adapted
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 4
#define CLK_PIN   D5
#define DATA_PIN  D7
#define CS_PIN    D1
// Hardware SPI connection
MD_Parola P = MD_Parola(HARDWARE_TYPE, CS_PIN, MAX_DEVICES);
// Arbitrary output pins
// MD_Parola P = MD_Parola(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
const char* ssid = "xxx";
const char* password = "xxxx";
const char* host = "api.coindesk.com";
float previousValue = 0.00;
float threshold = 0.05;
  pinMode(D3, OUTPUT); //Price down
  pinMode(D4, OUTPUT); //Price up
  delay(10);
  WiFi.begin(ssid, password);
  Serial.print("Connecting to ");
  Serial.println(ssid);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  P.begin();
  // Connect to API
  Serial.print("connecting to ");
  Serial.println(host);
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  const int httpPort = 80;
  if (!client.connect(host, httpPort)) {
    Serial.println("connection failed");
    return;
  // We now create a URI for the request
  String url = "/v1/bpi/currentprice.json";
  Serial.print("Requesting URL: ");
  Serial.println(url);
  // This will send the request to the server
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  delay(500); //geändert von 100
  // Read all the lines of the reply from server and print them to Serial
  String answer;
  while(client.available()){
    String line = client.readStringUntil('\r');
    answer += line;
  client.stop();
  Serial.println("closing connection");
  // Process answer
  Serial.println("Answer: ");
  Serial.println(answer);
  // Convert to JSON
  String jsonAnswer;
  int jsonIndex;
  for (int i = 0; i < answer.length(); i++) {
    if (answer[i] == '{') {
      jsonIndex = i;
  // Get JSON data
  jsonAnswer = answer.substring(jsonIndex);
  Serial.println("JSON answer: ");
  Serial.println(jsonAnswer);
  jsonAnswer.trim();
  // Get rate as float
  int rateIndex = jsonAnswer.indexOf("rate_float");
  String priceString = jsonAnswer.substring(rateIndex + 12, rateIndex + 18);
  priceString.trim();
  float price = priceString.toFloat();
  // Print price
  Serial.println("Bitcoin price: "
  Serial.println(price);
    P.print(String(price));
  // Init previous value
  if (previousValue == 0.00) {
    previousValue = price;
  // Alert down ?
  if (price < (previousValue - threshold)) {
    // Flash LED
    digitalWrite(D3, LOW);
    digitalWrite(D4, HIGH);
  // Alert up ?
 if (price > (previousValue + threshold)) {
    // Flash LED
    digitalWrite(D4, LOW);
    digitalWrite(D3, HIGH);
  // Store value
  // Wait 1 minute
  delay(60000);
Meine Fragen: Ist es möglich den Preis auf ganze Zahlen zu Beschränken (Als Bitcoinpreis 4021 und nicht 4021,50) oder die Anzeige mit dem Preis scrollen zu lassen?
Ich habe nur den P.print befehl wirklich als Anzeige reinbekommen. Mit dem Rest der MD_Parola stehe ich auf Kriegsfuß.
Wäre Klasse wenn ihr mir helfen könntet.
Hallo,
hiermit wird es abgeschnitten
Serial.println(price,0);
ansonsten musst du mathematisch runden
unsigned long z = price + 0.5;
Serial.println(z);
  priceString.trim();
  int price = priceString.toInt();
  Serial.print("Bitcoin price: ");
  // oder gleich so
  P.print(String(priceString.toInt()));
Gruß Fips
Danke Doc_Arduino das wars :grinning:
Serial.println(z);
So rundet er schön und ist auf ganze Zahlen beschränkt.
Auch Derfips, danke für deine Hilfe nur leider rundet er nicht mathematisch bei dieser Lösung
Die Anfoderung hieß ->>
GreenBrainArc:
Ist es möglich den Preis auf ganze Zahlen zu Beschränken....
Ich weiß Derfips
aber mit der Rundung sagt es mir eher zu :wink:
Wäre dieses nicht erwähnt worden würde ich auch deine Lösung nutzen.
