Wemos d1 mini pro freezing?
Hi guys, i have created a weather station based on Wemos d1 mini pro. Now it has 4 sensors connected. I have tested it some days ago, and was working completely fine for 3-4 days. Then it had a little break cause i wanted to add another sensor. Today i launched station again, to test it with added VEML6070 Adafruit UV sensor. It was working fine for 4 hours, then station stopped uploading data to database (im doing it every 5 minutes).
Here is my code:
#include <Adafruit_VEML6070.h>
#include <Adafruit_BMP085.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <WiFiClientSecure.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
#define ONE_WIRE_BUS 2
#define DHTPIN 0
#define DHTTYPE DHT21
DHT dht(DHTPIN, DHTTYPE);
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
Adafruit_BMP085 bmp;
Adafruit_VEML6070 uv = Adafruit_VEML6070();
//SSID of your network
char ssid[] = "xxx"; //SSID of your Wi-Fi router
char pass[] = "xxx"; //Password of your Wi-Fi router
char server[] = "xxx";
  dht.begin();
  uv.begin(VEML6070_1_T);
  if (!bmp.begin()) {
    Serial.println("Could not find BMP180 or BMP085 sensor at 0x77");
    while (1) {}
  delay(10);
  // Connect to Wi-Fi network
  Serial.print("Connecting to...");
  Serial.println(ssid);
  WiFi.begin(ssid, pass);
    Serial.print(".");
  Serial.println("");
  Serial.println("Wi-Fi connected successfully");
  Serial.println("IP address: ");
WiFiClient client;
void loop () {
  sensors.begin();
  sensors.requestTemperatures();
  float temperatura = sensors.getTempCByIndex(0);
  Serial.println("temperatura: ");
  Serial.println(temperatura);
  delay(2000);
  float tt = dht.readTemperature();
  float h = dht.readHumidity();
  Serial.println("Temperatura DHT: ");
  Serial.println(tt);
  Serial.println("Wilgotnosc: ");
  Serial.println(h);
  delay(2000);
  float seaLevelPressure = 101890;
  float t = bmp.readTemperature();
  float p = bmp.readPressure()/100;
  Serial.println("temperatura BMP: ");
  Serial.println(t);
  Serial.println("Cisnienie hPa:");
  Serial.println(p);
  delay(2000);
  double uvNow = uv.readUV()*0.05625;
    Serial.println("Natezenie UV W/m2: ");
    Serial.println(uvNow);
  if (client.connect(server, 80)) {
    Serial.println("connecting...");
    // send the HTTP GET request:
    client.print("GET /data.php?temperatura=" ) ;
    client.print(temperatura);
    client.print("&");
    client.print("wilgotnosc=");
    client.print(h);
    client.print("&");
    client.print("cisnienie=");
    client.print(p);
    client.print("&");
    client.print("irradiancja=");
    client.print(uvNow);
    client.print("&");
    client.println( " HTTP/1.1");    // embedded space and println !
    client.println("Host: xxx");
    client.println("Connection: close");
    client.println();
    Serial.println("Dane przeslane pomyslnie!");
    Serial.println("ESP going to sleep!");
    ESP.deepSleep(300e6);
As u can see every 5 minutes im launching deepsleep on esp to save energy. I power the wemos through 5V/1A samsung charger with micro usb. Is it software problem that it freezes?
