Hi. I am using ESP8266 based board, Wemos D1 mini. The problem is that for some reason my board is recognized by the computer only when the RESET button is pressed, which makes uploading program impossible. Everything worked properly before, but then changed (don't know why). What I did:
-made sure USB connections are ok
-made sure i have correct driver CH340 installed (CH341SER to be exact)
-made sure my USB cable supports not only power delivery but also transmission
-tried uploading to board while pressing the RESET button so that it is recognizable during the process, but for obvious reasons this didin't work.
Any ideas on how to bring my board back to normal? It can't be used in its current state.
Thanks in advance
