Wemos d1 mini wifi scan
Hi
New on the forum.
i have a wifi scan program with wemos d1 mini and a lcd.
i have attached a button to D5.
now i want to show the first ssid and stop until i press the button and then show second ssid etc.
but i can´t figure it out.
anyone has any ideas?
Robert
code:
#include "ESP8266WiFi.h"
#include <Wire.h>
WiFiClient client;
LiquidCrystal_I2C lcd(0x27,16,2);
const int RSSI_MAX =-50;// define maximum strength of signal in dBm
const int RSSI_MIN =-100;// define minimum strength of signal in dBm
int i=1;
lcd.init(); // initialize the lcd
lcd.init();
// Print a message to the LCD.
lcd.backlight();
pinMode(D5, INPUT_PULLUP);
SSID_scan();
delay(10000);
void SSID_scan() {
lcd.clear();
Serial.println("");
Serial.println("scan start");
lcd.setCursor(0,0);
lcd.print("Scan started");
WiFi.disconnect();
delay(100);
// WiFi.scanNetworks will return the number of networks found
int n = WiFi.scanNetworks();
if (n == 0) {
Serial.println("no networks found");
lcd.setCursor(3,0);
lcd.print("No networks found");
Serial.print(n);
Serial.println(" networks found");
 lcd.setCursor(0,1);
   lcd.print(n);
   lcd.setCursor(2,1);
lcd.print("Networks found...");
delay(3000);
for (int i = 0; i < n; ++i)
  // Print SSID and RSSI for each network found
  Serial.print(i + 1);
  Serial.print(": ");
  Serial.print(WiFi.SSID(i));
  Serial.print(WiFi.RSSI(i));
  Serial.print(" (");
  lcd.clear();
  lcd.print(WiFi.SSID(i));
  lcd.setCursor(0,1);
  lcd.print("dBm:");
  lcd.print(WiFi.RSSI(i));
  lcd.setCursor(10,1);
  lcd.print(dBmtoPercentage(WiFi.RSSI(i)));//Signal strength in %
  lcd.print("%");
  int button=digitalRead(D5);
  if (button==HIGH){
Serial.println("scan done");
lcd.print("Scan Done.");
Serial.println("");
String encryptionTypeStr(uint8_t authmode) {
switch (authmode) {
case ENC_TYPE_NONE:
return "NONE";
case ENC_TYPE_WEP:
return "WEP";
case ENC_TYPE_TKIP:
return "TKIP";
case ENC_TYPE_CCMP:
return "CCMP";
case ENC_TYPE_AUTO:
return "AUTO";
default:
return "?";;
int dBmtoPercentage(int dBm)
int quality;
if(dBm <= RSSI_MIN)
quality = 0;
else if(dBm >= RSSI_MAX)
quality = 100;
quality = 2 * (dBm + 100);
 return quality;
}//dBmtoPercentage
Welcome to the forum
Why did you start a topic in the Uncategorised category of the forum when its description is
:warning: DO NOT CREATE TOPICS IN THIS CATEGORY :warning:
Your topic has been moved to the Programming category
Use [color = red]code tags[/color] (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Sounds interesting, but I cannot read your code nor your schematic showing how it is connected.
@robban75 Hi Robban and welcome to the forum, I realy don´t understand why you´re surching ssid´s when you want to connect to WiFi? You want to use it as a WiFi scanner and use it on the field? You want to display all the WiFi connections available? Right? But how to connect to them is something else, you might need a password.
Greetings dingsken.
