Wemos D1 R1 + Grove shield + DHT11
Hi. I searched in the forums and could not find anything relevant to my issue. Also, my knowledge in electronics are quite limited so sorry in advanced.
I bought Arduino Uno and Grove shield plus DHT sensor. It's reading fine.
Then I though I wanted to integrate with Blynk so I bought Wemos D1 R1 since it was Arduino compatible and has wifi connectivity. I also read that it could work with the Grove shield with some peculiarities.
Wemos connects to network nicely. It also detects DHT11 sensor connected to the Grove shield (connected to Wemos) but all the readings are always 0s for temperature and humidity.
I have little knowledge about electronics but I read something about Wemos operating on 3.3v vs 5v required by the sensor.
Could anyone help me here not only solving the problem but pointing me out to good resources where I could also get to understand this issue more in depth?
The D1 is not really compatible with the Arduino it just uses the same IDE and if your strictly used the IDE internal libraries (and not other access to the hardware) you usually get Arduino sketches compiles and often they also run.
Many DHT11 libraries are written for the AVR Arduinos and don't work on other hardware. As you failed to post your sketch as well as you failed to post links to the used libraries (as the sticky post at the top of the topic instructs you) we are not able to help you further.
pylon:
Sorry for the missing info and thank you for the reply, was a useful comment for me overall.
Don't you want to post your sketch and the links or was the help already sufficient?
