Hi Mikba and welcome to the forum. You should really read this before posting a message so you understand the etiquette and how to put your code in a code tags to make it more readable.
I have not looked at your code but a quick search on the RC552 seems to indicate it’s a 3.3V board so that’s a good start.
It would help if you had posted links to the Lolin32 OLED board your using and maybe give some details on the settings your using to program it. If your using the “Wemos Lolin32” board definition (I cannot see one for the OLED board) then the SPI pins your using (SCLK (SCK) = 14, MISO = 12, MOSI = 13, SS (SDA?) = 15, RST = 5) are probably wrong.
If your board looks like the below image then I think the wiring should be…
SCK to CL
MISO to SO
MOSI to SI
SS to 5
Not sure why you would be getting the crash like that but try removing the return; you have in the loop code as you don’t really have anywhere to return to.
I don’t have a RFID card and I’m at work so no access to an ESP32 to test with.
Is the RC522 library you have installed the latest version (currently 1.4.0) and do you have a pinout (see below example) of the Lolin32 OLED board your using just in case the problem is with the pin numbers.
@Rickypaul
Changing pin assignment should be same like on WinOS.
Just search in your "arduino"-directory for pins_arduino.h. You'll find lots of files with its name. Choose that one which is in "arduino/hardware/espressif/esp32/variants/YOUR_BOARD" and edit it.
