Wemos mega with esp8266
Hi all,
Please tell me if im barking up the wrong tree.
I have a project running my stairlights which runs on a Arduino MEGA all is well here.
I have also have OTA projects running on wemos D1 mini which are all good too.
Now the interesting part, I have purchased a wemos mega with intergrated esp8266. My aim is to be able to play with the program an OTA upload the new program edits via esp8266 without removing from situe which is kind of awkward to remove.
Is this possible ??
I know i can OTA upload the esp8266 not an issue but can i then send via serial or another method to the atmega chip on the wemos board.
i understand there may be a compiler issue between the two devices even if mounted on the same board.
I not know the answer and will keep playing until i either work it out or have no hair lol.
hope this is possible and look forward to your responses.
Kind regards
It is Robotdyn. Wemos doesn't make Megas
see EspLink
check this out pretty sure it says wemos on it
here with docs and schemas on the manufacturers site
Ok so back to the original question do you think what im trying to do is possible ?? any hints or clues to aid me in my quest ??
regards
see answer #1
