WEMOS motor shield v 1.0 + Arduino UNO by I2C
Hi.
Somebody used the WEMOS library from
WEMOS_Motor_Shield_Arduino_Library
for communicating with Arduino UNO?
I'm attached WEMOS motor shield.
Upgrade with new firmware from here:
hackaday
Simple code easy to detected shield on address 0x30 but nothing happened when I'm trying to use the simple WEMOS library example code.
Like this:
#include "WEMOS_Motor.h"
int pwm;
//Motor shiled I2C Address: 0x30
//PWM frequency: 1000Hz(1kHz)
 Motor M1(0x30, _MOTOR_A, 1000); //Motor A
  for (pwm = 40; pwm <= 100; pwm++)
    M1.setmotor( _CW, pwm);
//    sprintf( txt, "A:%d%, B:%d%, DIR:CW\r\n", pwm, 100 - pwm);
    Serial.println( txt );
    M1.setmotor(_STANDBY);
    Serial.println("Motor A STANDBY");
    delay(100);
It doesn't work.
Ok.
I'm found some idea.
In the code of class Motor using some code that can't be used before setup module in Arduino code :o
Solution is:
int pwm;
Motor *M1;
  M1 = new Motor(0x30, _MOTOR_A, 1000); //Motor A
    M1->setmotor( _CW, pwm);
    M1->setmotor(_STANDBY);
    delay(100);
But it doesn't work anyway >:(
I made the setup "log":
  Serial.println("Let's start!");
Wtf!
Now it's work perfectly!!!
Without using Serial it works fine.
With "setup" using Serial.print function it works fine.
But what's wrong?
:blush:
What is wrong is you missed some vital posts one the way here..
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Then you can post the code properly.
