I have a Wemos D1 mini with one button on D5. If pressed it has to sent 2 OSC messages and when release it has to sent 2 messages again.
Using the code it will contact my Wifi. But I get a crash when one of the sent routines is called. Any thoughts?
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (3):
epc1=0x40100615 epc2=0x00000000 epc3=0x00000000 excvaddr=0x4002f521 depc=0x00000000
stack>>>
ctx: cont
sp: 3ffffda0 end: 3fffffd0 offset: 0150
3ffffef0: 000005c0 000000b8 3ffe85fc 401006ce
3fffff00: 000005c0 000000b8 3ffe85fc 3ffee660
3fffff10: 3ffef4c4 00000020 3ffef4ec 40100a1c
3fffff20: 3fffdad0 00000000 3ffef4c4 4020262c
3fffff30: 3fffdad0 00000020 3fffff50 4020218f
3fffff40: 3fffdad0 00000000 3ffee570 402012b8
3fffff50: 3ffef57c 00000002 00000000 00000000
3fffff60: 00000000 00000000 00000000 00000000
3fffff70: 3fffdad0 3ffef4ec 00000000 00000000
3fffff80: 00000000 00000000 3ffef73c 00000000
3fffff90: 00000010 40205f88 1001a8c0 3ffee660
3fffffa0: 3fffdad0 00001528 3ffee634 40201388
3fffffb0: 3fffdad0 00000000 3ffee634 40203318
3fffffc0: feefeffe feefeffe 3fffdab0 40100dc9
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3424, room 16
tail 0
chksum 0x2e
load 0x3fff20b8, len 40, room 8
tail 0
chksum 0x2b
csum 0x2b
v00043f30
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
//#include <OSCMessage.h>
#include <OSCBundle.h>
// #include <OSCData.h>
const int StatusLed = LED_BUILTIN;
const int SwitchButton = D5;
int LastState = HIGH;
char ssid[] = "WorstCase24"; // your network SSID (name)
char pass[] = "XXXXXX"; // your network password
WiFiUDP Udp; // A UDP instance to let us send and receive packets over UDP
const IPAddress outIp(192, 168, 1, 16); // remote IP of your computer
const unsigned int outPort = 10024; // remote port to receive OSC
const unsigned int localPort = 30000; // local port to listen for OSC packets (actually not used for sending)
pinMode(StatusLed, OUTPUT);
digitalWrite(StatusLed, HIGH);
pinMode(SwitchButton, INPUT);
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
digitalWrite(StatusLed, LOW);
delay(100);
delay(400);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("IP address: ");
Serial.println("Starting UDP");
Udp.begin(localPort);
Serial.print("Local port: ");
#ifdef ESP32
Serial.println(localPort);
#else
Serial.println(Udp.localPort());
#endif
Serial.print("Mixer IP address: ");
Serial.println(outIp);
Serial.print("Mixer Port: ");
Serial.println(outPort);
bool sensorVal = digitalRead(SwitchButton);
if (LastState != sensorVal) {
LastState = sensorVal;
if (sensorVal == HIGH) {
SwitchOff();
SwitchOn();
delay(100);
void SwitchOn() {
OSCBundle bundle;
OSCMessage msg = bundle.add("/ch/07/mix/on");
msg.add(0);
bundle.add("/ch/08/mix/on");
msg.add(1);
Udp.beginPacket(outIp, outPort);
bundle.send(Udp);
Udp.endPacket();
//msg.empty();
Serial.println(F("MUTE ON"));
void SwitchOff() {
OSCBundle bundle;
msg.add(1);
msg.add(0);
bundle.send(Udp);
Udp.endPacket();
//msg.empty();
Serial.println(F("MUTE OFF"));
