wemos thingspeak dht11
i can only be reading from one sensor is there is anything wrong with the code
#include <DHT.h>
#include <ESP8266WiFi.h>
// replace with your channel’s thingspeak API key and your SSID and password
String apiKey = "7278LJY09HZVM2ZS";
const char* ssid = "murattu kalai";
const char* password = "thalapathy";
const char* server = "api.thingspeak.com";
DHT dht1(D8, DHT11);
DHT dht2(D3, DHT11);
DHT dht3(D2, DHT11);
WiFiClient client;
  delay(10);
  dht1.begin();
  dht2.begin();
  dht3.begin();
  WiFi.begin(ssid, password);
  Serial.print("Connecting to ");
  Serial.println(ssid);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  float h1 = dht1.readHumidity();
  float t1 = dht1.readTemperature();
  float h2 = dht2.readHumidity();
  float t2 = dht2.readTemperature();
  float h3 = dht3.readHumidity();
  float t3 = dht3.readTemperature();
  if (isnan(h1) || isnan(t1))
    if (isnan(h2) || isnan(t2))
      if (isnan(h3) || isnan(t3))
        Serial.println("Failed to read from DHT1 sensor!");
        Serial.println("Failed to read from DHT2 sensor!");
        Serial.println("Failed to read from DHT3 sensor!");
        return;
  if (client.connect(server, 80)) {
    String postStr = apiKey;
    postStr += "&field1=";
    postStr += String(t1);
    postStr += "&field2=";
    postStr += String(h1);
    postStr += "&field3=";
    postStr += String(t2);
    postStr += "&field4=";
    postStr += String(h2);
    postStr += "&field5=";
    postStr += String(t3);
    postStr += "&field6=";
    postStr += String(h3);
    postStr += "\r\n\r\n";
    client.print("POST /update HTTP/1.1\n");
    client.print("Host: api.thingspeak.com\n");
    client.print("Connection: close\n");
    client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
    client.print("Content-Type: application/x-www-form-urlencoded\n");
    client.print("Content-Length: ");
    client.print(postStr.length());
    client.print("\n\n");
    client.print(postStr);
    Serial.print("Temperature1: ");
    Serial.print(t1);
    Serial.print(" degrees Celsius Humidity1: ");
    Serial.print(h1);
    Serial.println("Sending data to Thingspeak");
    Serial.print("Temperature2: ");
    Serial.print(t2);
    Serial.print(" degrees Celsius Humidity2: ");
    Serial.print(h2);
    Serial.print("Temperature3: ");
    Serial.print(t3);
    Serial.print(" degrees Celsius Humidity3: ");
    Serial.print(h3);
  client.stop();
  Serial.println("Waiting 20 secs");
  // thingspeak needs at least a 15 sec delay between updates
  // 20 seconds to be safe
  delay(20000);
This code is probably not doing what you expect it to do:
        return;
What does that mean? Do you get an error from the others?
BTW, you should read the temperature first as in readTemperature() the reading is forced while in readHumidity() a value from the previous readTemperature() is used if available.
Post a wiring diagram of your setup.
