///////////////////////////////////////////////Sender////////////////////////////////////////
#include <Arduino.h>
* Displays text sent over the serial port (e.g. from the Serial Monitor) on
* an attached LCD.
* YWROBOT
*Compatible with the Arduino IDE 1.0
*Library version:1.1
#include <Wire.h>
#include <OneWire.h>
#include <Ultrasonic.h>
uint8_t a;
uint8_t b;
int enablePin = 13;//RS485 Master/Slave pin Master = Sender = HIGH
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
Ultrasonic ultrasonic1(4, 5); // An ultrasonic sensor HC-04
int distance = 0;
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// https://github.com/milesburton/Arduino-Temperature-Control-Library
OneWire ds(8); // on pin 10 (a 4.7K resistor is necessary)
//Sensoren
float temperaturOfen = 0;
byte adresseOfenTemperaturSensor[] = {0x28, 0x22, 0x54, 0x55, 0x42, 0x20,0x01, 0xF4, 0xF8};//Dec={40,34,84,85,66,32,1,244,248};
float temperaturDach = 0;
byte adresseDachTemperaturSensor[] = {0x28, 0x83, 0x1B, 0x91, 0x42, 0x20, 0x01, 0x2E};//Dec={40,131,27,145,66,32,1,46};
float temperaturAussen = 0;
byte adresseAussenTemperaturSensor[] = {0x28, 0xE5, 0x4C, 0x92, 0x42, 0x20, 0x01, 0x13};//Dec={40,229,76,146,66,32,1,19};
float temperaturPufferOben = 0;
byte adressePufferObenTemperaturSensor[] = {0x28,0xF8,0xF3,0x64,0x42,0x20,0x01,0x5A};//{40,248,243,100,66,32,1,90};
float temperaturPufferUnten = 0;
byte adressePufferUntenTemperaturSensor[] = {0x28, 0x2B, 0x82, 0x5C, 0x42, 0x20, 0x01,0x33};//Dec={40,43,130,92,66,32,1,51};
//Variablen
unsigned long timerLcd = 5000;
unsigned long speicherMillisTimerLcd = 0;
int zaehlerLcd = 0;
float getTemperatur (byte adresseSensor[8])
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius;
for ( int a = 0;a < 8; a++){addr[a] = adresseSensor[a];}
//Serial.print("ROM =");
for( i = 0; i < 8; i++) {
//Serial.write(' ');
//Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
//Serial.println("CRC is not valid!");
return;
//Serial.println();
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
//Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
case 0x28:
//Serial.println(" Chip = DS18B20");
type_s = 0;
case 0x22:
//Serial.println(" Chip = DS1822");
type_s = 0;
default:
//Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
//Serial.print(" Data = ");
//Serial.print(present, HEX);
//Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
//Serial.print(data[i], HEX);
//Serial.print(" CRC=");
//Serial.print(OneWire::crc8(data, 8), HEX);
//Serial.println();
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
a = data[1];
b = data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
//fahrenheit = celsius * 1.8 + 32.0;
//Serial.print(" Temperature = ");
//Serial.print(celsius);
//Serial.print(" Celsius, ");
//Serial.print(fahrenheit);
//Serial.println(" Fahrenheit");
return celsius;
int getValueUltrasonic()
//Serial.print("Sensor 01: ");
//Serial.print(ultrasonic1.read()); // Prints the distance on the default unit (centimeters)
//Serial.println("cm");
return ultrasonic1.read();
void sendeDatenRS485(float temp0,float temp1,float temp2,float temp3,float temp4, int ultra, int photo)
unsigned char signMinus[7];//Vorzeichenerkennung 1 = Minus und negative Werte positiv machen zum senden
if ( temp0 < 0.00) {signMinus[0] = 1; temp0 = temp0 * -1.00;} else { signMinus[0] = 0;}
if ( temp1 < 0.00) {signMinus[1] = 1; temp1 = temp1 * -1.00;} else { signMinus[1] = 0;}
if ( temp2 < 0.00) {signMinus[2] = 1; temp2 = temp2 * -1.00;} else { signMinus[2] = 0;}
if ( temp3 < 0.00) {signMinus[3] = 1; temp3 = temp3 * -1.00;} else { signMinus[3] = 0;}
if ( temp4 < 0.00) {signMinus[4] = 1; temp4 = temp4 * -1.00;} else { signMinus[4] = 0;}
signMinus[5] = 0;
signMinus[6] = 0;
Serial.println('s');//1
float f[] = {temp0,temp1,temp2,temp3,temp4};
for ( int i = 0; i < 5; i++)
byte* bytes = (byte*) & f[i];
Serial.print(signMinus[i]); Serial.print(',');//10 / 11
for ( int j = 0; j < 4; j++)
Serial.print(bytes[j]); Serial.print(',');//40 / 51
byte signMinus56[2];
signMinus56[0] = signMinus[5];
signMinus56[1] = signMinus[6];
unsigned int value[2];
value[0] = ultra * 100;
value[1] = photo * 100;
for ( int i = 0; i < 2; i++)
byte a = value[i] / 255;
byte b = value[i] % 255;
Serial.print(signMinus56[i]); Serial.print(',');
Serial.print(a); Serial.print(',');
Serial.print(b); Serial.print(',');//12 byte / 63 byte
void printEinheit (String einheit)
lcd.setCursor(10,1);
lcd.print(einheit);
void visualisiereLcd(float temp1,float temp2,float temp3,float temp4,float temp5, int ultra, int photo)
if ( millis() > (speicherMillisTimerLcd + timerLcd))
speicherMillisTimerLcd = millis();
zaehlerLcd++;
if (zaehlerLcd > 7){zaehlerLcd = 1;}
lcd.clear();
switch (zaehlerLcd)
case 1:
lcd.setCursor(0,0);
lcd.print("1/7 Ofen:");
lcd.setCursor(0,1);
lcd.print(temp1);
printEinheit("GradC.");
case 2:
lcd.setCursor(0,0);
lcd.print("2/7 PufferOben:");
lcd.setCursor(0,1);
lcd.print(temp2);
case 3:
lcd.setCursor(0,0);
lcd.print("3/7 PufferUnten:");
lcd.setCursor(0,1);
lcd.print(temp3);
case 4:
lcd.setCursor(0,0);
lcd.print("4/7 Aussen:");
lcd.setCursor(0,1);
lcd.print(temp4);
case 5:
lcd.setCursor(0,0);
lcd.print("5/7 Dach:");
lcd.setCursor(0,1);
lcd.print(temp5);
case 6:
lcd.setCursor(0,0);
lcd.print("6/7 Pellets:");
lcd.setCursor(0,1);
lcd.print(ultra);
printEinheit("cm");
case 7:
lcd.setCursor(0,0);
lcd.print("7/7 Licht:");
lcd.setCursor(0,1);
lcd.print(photo);
printEinheit("/1023");
lcd.init(); // initialize the lcd
lcd.backlight();
delay(10);
pinMode(enablePin, OUTPUT);
digitalWrite(enablePin,HIGH);//zum senden als Master
for(int j = 0; j < 5; j++)
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
//Serial.println("No more addresses.");
//Serial.println();
ds.reset_search();
delay(0);
return;
return;
//Serial.println();
switch (addr[0]) {
case 0x10:
type_s = 1;
case 0x28:
type_s = 0;
case 0x22:
type_s = 0;
default:
return;
ds.reset();
ds.select(addr);
delay(0); // maybe 750ms is enough, maybe not
ds.select(addr);
//hier wird die Adresse vom angeschlossenen Dallas ausgegeben/////////////////////////////////////////////////////////////////
//lcd.setCursor(0,0);lcd.print(i); lcd.print(">"); lcd.print(addr[i]); lcd.print(";"); delay(5000);lcd.clear();
//Serial.println();
if (type_s) {
//temperaturInput
temperaturOfen = getTemperatur(adresseOfenTemperaturSensor);
temperaturPufferOben = getTemperatur(adressePufferObenTemperaturSensor);
temperaturPufferUnten = getTemperatur(adressePufferUntenTemperaturSensor);
temperaturAussen = getTemperatur(adresseAussenTemperaturSensor);
temperaturDach = getTemperatur(adresseDachTemperaturSensor);
///////////////ultraschallSensor////////////////////////
//distance = getValueUltrasonic();
//Serial.println (distance);
///////////////photozelle////////////////////
//int lichtWert = analogRead (7);
///////////////lcd////////////////////////
//visualisiereLcd(temperaturOfen, temperaturPufferOben, temperaturPufferUnten,temperaturAussen, temperaturDach, distance, lichtWert);
//////////////RS485//////////////////////////
//sendeDatenRS485(temperaturOfen, temperaturPufferOben, temperaturPufferUnten,temperaturAussen, temperaturDach, distance, lichtWert);
Serial.print(a); Serial.println(b);
/////////////////////////////////////////////////Empfänger///////////////////////////////////////////////
//SLAVE CODE: (Arduino NANO):
//Slave code (Arduino NANO)
//Serial Communication Between Two Arduinos using RS-485
//Circuit Digest
const int NUMBER_OF_FIELDS = 21;//Anzahl der Felder die empfangen werden
int value[NUMBER_OF_FIELDS];//Speicherplätze für eingehende Felder
int fieldIndex = 0;
int enablePin = 13; //Schalter zwischen senden und empfangen
Serial.begin(9600); // initialize serial at baudrate 9600:
delay(10);
digitalWrite(enablePin, LOW); // (Pin 8 always LOW to receive value from Master)
int anzahl = 2;
unsigned char ch [anzahl];
while (Serial.available() >0)
for ( int i = 0; i < anzahl; i++)
ch[i] = Serial.read();
Serial.print(ch[i]);
//Serial.println();
//delay(2000);
if ( Serial.available() > 0)
char ch = Serial.read();//einlesen eines Charakters
if ( ch >= '0' && ch <= '9')//wenn Zahl..
if ( fieldIndex < NUMBER_OF_FIELDS)//wenn noch Felder erwartet werden ..
value[fieldIndex] = value[fieldIndex] * 10 + (ch - '0');//Charakter in Speicher schieben
// *10 setzt eine Stelle höher und ch-0 verhindert, dass noch eine 0 mehr hinten angefülgt wird
else if (ch == ',')
fieldIndex++;//Sprung zum nächsten Feld
for ( int i = 0; i < min (NUMBER_OF_FIELDS, fieldIndex+1); i++)
Serial.print(i); Serial.print("->");Serial.println(value[i]);
value[i]=0;
fieldIndex = 0;
