Wetterdaten im Arduino benutzen
Hallo Zusammen,
ich möchte gerne Wetterdaten in meinem Arduino benutzen. Allerdings gelingt mir das momentan nicht.
Vllt kann mir ja einer weiterhelfen.
Anbei mein momentaner sketch.
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0E, 0xC8, 0x3B };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
char server[] = "http://weather.yahooapis.com";    // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 1, 174);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // try to congifure using IP address instead of DHCP:
    Ethernet.begin(mac, ip);
  // give the Ethernet shield a second to initialize:
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.println("GET /forecastrss?w=633175&u=c");
    client.println("Host: http://weather.yahooapis.com");
    client.println("Connection: close");
    client.println();
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    while (true);
Setze Deinen Sketch bitte in Codetags (</> oben links im Editor) so dass er auf allen Geräten lesbar ist.
Gruß Tommy
Jetzt wo Uwe dir das erledigt hast, solltest du eventuell erzählen, was genau dein Problem ist.
Ich z.B. erhalte mit einem Browser
Die DNS-Adresse des Servers von weather.yahooapis.com wurde nicht gefunden. Meinten Sie http://www.yahooapis.com/weather/?
connecting... connected HTTP/1.0 400 Bad HostPort Content-Length: 0 Date: Mon, 13 Nov 2017 15:54:15 GMT Age: 0 Via: http/1.1 a29.ue.bf1.yahoo.net (ApacheTrafficServer [cMsSf ]) Server: ATS Public-Key-Pins-Report-Only: max-age=2592000; pin-sha256="2oALgLKofTmeZvoZ1y/fSZg7R9jPMix8eVA6DH4o/q8="; pin-sha256="cAajgxHlj7GTSEIzIYIQxmEloOSoJq7VOaxWHfv72QM="; pin-sha256="SVqWumuteCQHvVIaALrOZXuzVVVeS7f4FGxxu6V+es4="; pin-sha256="UZJDjsNp1+4M5x9cbbdflB779y5YRBcV6Z6rBMLIrO4="; pin-sha256="JbQbUG5JMJUoI6brnx0x3vZF6jilxsapbXGVfjhN8Fg="; pin-sha256="lnsM2T/O9/J84sJFdnrpsFp3awZJ+ZZbYpCWhGloaHI="; pin-sha256="h6801m+z8v3zbgkRHpq6L29Esgfzhj89C1SyUCOQmqU="; pin-sha256="SQVGZiOrQXi+kqxcvWWE96HhfydlLVqFr4lQTqI5qqo="; pin-sha256="q5hJUnat8eyv8o81xTBIeB5cFxjaucjmelBPT2pRMo8="; pin-sha256="vPtEqrmtAhAVcGtBIep2HIHJ6IlnWQ9vlK50TciLePs="; pin-sha256="lpkiXF3lLlbN0y3y6W0c/qWqPKC7Us2JM8I7XCdEOCA="; pin-sha256="r/mIkG3eEpVdm+u/ko/cwxzOMo1bk4TyHIlByibiA5E="; pin-sha256="WoiWRyIOVNa9ihaBciRSC7XHjliYS9VwUGOIud4PB18="; pin-sha256="2fRAUXyxl4A1/XHrKNBmc8bTkzA7y4FB/GLJuNAzCqY="; pin-sha256="dolnbtzEBnELx/9lOEQ22e6OZO/QNb6VSSX2XHA3E7A="; includeSubdomains; report-uri="http://csp.yahoo.com/beacon/csp?src=yahoocom-hpkp-report-only"
disconnecting.
Das bekomme ich momentan angezeigt habe meinen sketch an zwei stellen geändert
char server[] = "query.yahooapis.com"; client.println("GET /v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid=669787%20and%20u=%27c%27&format=xml&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys HTTP/1.0");
jetzt solltest du den link auch im browser eingeben können.
Mein Browser macht jedenfalls eine https-Gedöns - Unterhaltung mit yahoo draus.
Und wertet einen DigiCert - zertifizierten Schiüssel aus. Das wird deinen Arduino überfordern.
