Wetterstation
Guten Tag, Ich habe folgendes Programm:
#include <MPL3115A2.h>
#include <SPI.h>
#include <SD.h>
#include "DHT.h"
#include <Wire.h>
#include <ds3231.h>
//#include "SparkFunMPL3115A2.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
MPL3115A2 myPressure;
DS3231 clock;
RTCDateTime dt;
const int chipSelect = 4;
const int trigPin = 24;
const int echoPin = 22;
long duration;
int distance;
int interruptPin = 3;
volatile int state = 0 ;
uint32_t millis_alt;
uint32_t millis_alt1;
#define DHT22PIN 32
#define DHT22TYPE DHT22
DHT dht22(DHT22PIN, DHT22TYPE);
  Wire.begin();
  pinMode(interruptPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin), change_status, LOW);
  Serial.println("Initialize DS3231");
  clock.begin();
  clock.setDateTime(__DATE__, __TIME__);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  lcd.begin(16, 2);
  myPressure.begin();
  dht22.begin();
  myPressure.setModeBarometer();
  myPressure.setOversampleRate(7);
  myPressure.enableEventFlags();
  while (!Serial) {
  Serial.print("Initialisiere SD-Karte");
  if (!SD.begin(chipSelect)) {
    Serial.println("Karte nicht gefunden");
    return;
  Serial.println("Karte erfolgreich initialisiert");
void change_status() {
  state = state+1 ;
  if
  (state >= 4) {    // Wenn Status > 4 ,dann ...
    state = 0 ;    // ... Status zurücksetzen , default = 0
void printValues(String sensor, float humidy, float temp) {
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = duration * 0.034 / 2;
  float helligkeit = analogRead(A0);
  float standorthoehe = 278 ;
  float pressure = myPressure.readPressure();
  float press_hPa = pressure / 100 ;
  float differenz = standorthoehe / 8 ;
  float pressure_1 = differenz + press_hPa ;
  float pressure_hPa = pressure_1 ;
//  File dataFile = SD.open("datalog.txt", FILE_WRITE);
//  if (dataFile) {
//    dataFile.print(clock.dateFormat("d-m-Y", dt));
//    dataFile.print(" ");
//    dataFile.print(clock.dateFormat("H:i:s", dt));
//    dataFile.print(helligkeit);                        //Speichern der Messwerte in der geöffneten Datei
//    dataFile.print(" ");                              //Trennzeichen für die .txt (DATALOG.txt) Datei
//    dataFile.print(distance);
//    dataFile.print(humidy);
//    dataFile.print(temp);
//    dataFile.print(pressure_hPa, 1);
//    dataFile.println(" ");
//    dataFile.close();
    Serial.print(clock.dateFormat("d-m-Y", dt));
    Serial.print(";");
    Serial.print(clock.dateFormat("H:i:s", dt));
    Serial.print(";");
    Serial.print(helligkeit);
    Serial.print(";");
    Serial.print(distance);
    Serial.print(";");
    Serial.print(humidy);
    Serial.print(";");
    Serial.print(temp);
    Serial.print(";");
    Serial.print(pressure_hPa, 1);
    Serial.println(";");
//  } else {
//    Serial.println("Fehler beim Öffnen!");
  dt = clock.getDateTime();
  float humidyDHT22 = dht22.readHumidity(); //relative Luftfeuchtigkeit vom Sensor DHT22 lesen
  float tempDHT22 = dht22.readTemperature(); //Temperatur vom Sensor DHT22 lesen
  if (isnan(humidyDHT22) || isnan(tempDHT22)) {
    Serial.println("DHT22 konnte nicht ausgelesen werden");
    if (millis() - millis_alt > 5000)
    { millis_alt = millis();
      printValues("DHT22", humidyDHT22, tempDHT22);
     // Serial.print(state);
    if (millis() - millis_alt1 > 200)
    { millis_alt1 = millis();
      if (state == 0) // Wenn Zähler gleich null
        lcd.clear();
        // set up the LCD's number of columns and rows:
        // Print a message to the LCD.
        lcd.setCursor(3, 0);
        lcd.print(clock.dateFormat("d-m-Y", dt));
        // set the cursor to column 0, line 1
        // (note: line 1 is the second row, since counting begins with 0):
        lcd.setCursor(4, 1);
        // print the number of seconds since reset:
        lcd.print((clock.dateFormat("H:i:s", dt)));
      if (state == 1)                      // Wenn Zähler gleich 1
        lcd.clear();
        lcd.print("LUFTDRUCK");
        lcd.setCursor(3, 1);
        lcd.print(pressure_hPa);
        lcd.print("hPa");
      if (state == 2)                      // Wenn Zähler gleich 1
        lcd.clear();
        lcd.print("LUFTFEUCHTIGKEIT");
        lcd.print(humidyDHT22);
        lcd.print("%");
      if (state == 3)                      // Wenn Zähler gleich 1
        lcd.clear();
        lcd.print("TEMPERATUR.");
        lcd.print(tempDHT22);
        lcd.print("°C");
      if (state == 4)                      // Wenn Zähler gleich 1
        lcd.clear();
        lcd.print("HELLIGKEIT");
        lcd.print(helligkeit);
Und bekomme folgende Fehlermeldung, ich bin mit meinem Latein am Ende
version_april01.ino:13:1: error: 'DS3231' does not name a type
version_april01.ino:14:1: error: 'RTCDateTime' does not name a type
version_april01.ino: In function 'void setup()':
version_april01.ino:38:53: error: 'digitalPinToInterrupt' was not declared in this scope
version_april01.ino:40:3: error: 'clock' was not declared in this scope
version_april01.ino: In function 'void printValues(String, float, float)':
version_april01.ino:125:18: error: 'clock' was not declared in this scope
version_april01.ino:125:44: error: 'dt' was not declared in this scope
version_april01.ino: In function 'void loop()':
version_april01.ino:170:3: error: 'dt' was not declared in this scope
version_april01.ino:170:8: error: 'clock' was not declared in this scope
Vielen Dank fuer jede hilfreiche Antwort!
Vermutlich verwendest du falsche Libraries.
Da wir deine Libraries nicht kennen, ist eine genaue Aussage nicht möglich.
HotSystems:
Ja, ich hatte Probleme die Library fuer das AdafruitMPL3115A2 herunterzuladen. Ich arbeite mit dem Raspberry pi
Ich habe die //#include "SparkFunMPL3115A2.h" durch die #include <MPL3115A2.h> ersetzt da ich die erste nicht installiert bekommen habe, die 2. jedoch.
Was mich am meisten nervt ist, dass das programm auf meinem macbook einwandfrei làuft.
Mit freundlichen Grüssen,
-------max
-->Offensichtlich hat der Compiler keine Probleme mit der MPL3115A2-Lib, sondern mit der ds3231-Lib :wink:
Ok, was kann ich dann dagegen tun ??
Danke,
max
local_weatherstation:
Danke,
max
Die richtige Library einsetzen.
Wir wissen nicht, welche du verwendest.
Ich habe die DS3231 von github.com herunterladen, ist das die falsche ?
Mit freundlichen Grüßen
Es gibt mehrere verschiedene DS3231-Libs auf github und Dein Code muss zur jeweiligen Lib passen.
Gruß Tommy
Interessant.....welche ?
Hast du mal geschaut, wie viele es da gibt ?
Ich habe jetzt die library von meinem mac genommen. Ich bekomme jetzt nur noch folgende fehlermeldung:
version_april01.ino:40:53: error: 'digitalPinToInterrupt' was not declared in this scope
Das ist doch schon mal eine gute Nachricht.
Welchen Arduino verwendest du ?
Edit:
Ersetze mal den Text: "digitalPinToInterrupt" per Tastatur.
Evtl. ist da ein Kopierfehler drin.
Ich verwende aktuell den Arduino MEGA 2560, ich habe auch darauf geachtet, dass man nur verschiedene Pins fuer den interrupt benutzen kann.
Warum wechselst du ständig deine Identität ?
Lies nochmal meinen letzten Post.
Ich verstehe das jetzt nicht ganz, ich wechsele doch keine identität ?
Wie soll ioch jetzt genau interruptto pin ersetzen ?
Ja dann sieh dir doch mal den Thread an.
Mal heißt du "local_weatherstation" dann mal "weatherstation_local"
Was bitte ist denn nun richtig ?
Und indem du den Text "digitalPinToInterrupt" per Tastatur neu tippst.
Keine Ahnung warum ich manchmal anders heiße, ich habe auf jedenfall nichts geändert.
Ich habe den Text neu eingetippt es kommt jedoch wieder die selbe Fehlermeldung, als vorher.
Mit freundlichen Grüßen ,
max
Das halte ich für sehr Merkwürdig. Du musst dich doch dann immer neu anmelden.
Von unterschiedlichen Geräten ?
kann sein.
gestern habe ich auf dem raspberry gepostet, heute auf dem mac
die Fehlermeldung verschwindet immer noch nicht .... mies
[/centerjetzt bin ich auf dem raspberry, heisse also jetzt anders :slight_smile: :slight_smile: :slight_smile:
weatherstation_local:
[/quote]
das ist Mist....solltest du ändern.
Wozu brauchst du überhaupt den Interrupt ?
Der wird von dir nicht verwendet, oder übersehe ich etwas ?
