I am adapting the Wham Jammer project from Notes and Volts for my own needs. I have a Whammy 5 and a Bass Whammy set to receive midi on channels 11 and 14 respectively.
The code I have attached below works as intended for the Bass Whammy on channel 14, however, the midi program change and control change messages are not being sent out for the Whammy 5 on channel 11.
If I remove all of the Bass Whammy functions (BW) from the code, it works as intended for the Whammy 5 and will send out messages on channel 11.
I am not getting any errors when compiling.
#include <MIDI.h>
#define LED 13
MIDI_CREATE_DEFAULT_INSTANCE();
// Globals
byte chordMode = 0;
// MIDI note arrays
byte twoOctave[] = { 0, 5, 11, 16, 21, 27, 32, 37, 42, 48, 53, 58, 64, 69, 74, 79, 85,
90, 95, 101, 106, 111, 117, 122, 127 };
byte twoOctaveDn[] = { 127, 122, 117, 111, 106, 101, 95, 90, 85, 79, 74, 69, 64, 58, 53, 48, 42,
37, 32, 27, 21, 16, 11, 5, 0 };
pinMode(LED, OUTPUT);
MIDI.begin(MIDI_CHANNEL_OMNI);
// MIDI channel 11 callbacks - Guitar Whammy
MIDI.setHandleNoteOn(HandleNoteOnGW);
MIDI.setHandleNoteOff(HandleNoteOffGW);
MIDI.setHandlePitchBend(HandlePitchBendGW);
MIDI.setHandleControlChange(HandleCCGW);
// MIDI channel 14 callbacks - Bass Whammy
MIDI.setHandleNoteOn(HandleNoteOnBW);
MIDI.setHandleNoteOff(HandleNoteOffBW);
MIDI.setHandlePitchBend(HandlePitchBendBW);
MIDI.setHandleControlChange(HandleCCBW);
MIDI.read();
// Functions for Guitar Whammy on MIDI channel 11
void HandleNoteOnGW(byte channel, byte pitch, byte velocity) {
if (channel == 11) {
if (velocity == 0) {
digitalWrite(LED, LOW);
MIDI.sendControlChange(11, 0, 11);
digitalWrite(LED, HIGH);
MIDI.sendControlChange(11, noteConvertGW(pitch), 11);
void HandleNoteOffGW(byte channel, byte pitch, byte velocity) {
void HandlePitchBendGW(byte channel, int bend) {
if (bend < 0) {
bend = map(bend, -8192, 0, 127, 0);
MIDI.sendProgramChange((8 + chordMode), 11);
bend = map(bend, 0, 8192, 0, 127);
MIDI.sendProgramChange((0 + chordMode), 11);
MIDI.sendControlChange(11, bend, 11);
byte noteConvertGW(byte note) {
if (note >= 0 && note <= 23) {
return twoOctaveDn[note];
} else if (note >= 24 && note <= 48) {
return twoOctave[note - 24];
return 0;
void HandleCCGW(byte channel, byte number, byte value) {
if (number == 64) {
if ((value >= 64) && (value <= 127)) chordMode = 42;
else chordMode = 0;
// Functions for Bass Whammy on MIDI channel 14
void HandleNoteOnBW(byte channel, byte pitch, byte velocity) {
if (channel == 14) {
MIDI.sendControlChange(11, 0, 14);
MIDI.sendControlChange(11, noteConvertBW(pitch), 14);
void HandleNoteOffBW(byte channel, byte pitch, byte velocity) {
void HandlePitchBendBW(byte channel, int bend) {
if (bend < 0) {
MIDI.sendProgramChange((8 + chordMode), 14);
MIDI.sendProgramChange((0 + chordMode), 14);
MIDI.sendControlChange(11, bend, 14);
byte noteConvertBW(byte note) {
return 0;
void HandleCCBW(byte channel, byte number, byte value) {
if (number == 64) {
else chordMode = 0;
