At first I used Arduino to just run simple codes like this one:
Serial.println(“Walid”);
And upload it to arduino and run it on serial monitor. But then I wrote a code :
pinMode (A5,INPUT);
int pot = analogRead (A5);
Serial.println(pot);
and connected a potentio-meter at A5 and the side pins with 5 volts and ground. And it worked! I could see the values changing on serial monitor. But when I increased it to the max 1023 after a couple of seconds the software gave me an error saying :
Arduino: 1.8.2 (Windows 10), Board: “Arduino/Genuino Uno”
Sketch uses 1864 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 186 bytes (9%) of dynamic memory, leaving 1862 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can’t open device “\.\COM7”: The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
“Show verbose output during compilation”
option enabled in File → Preferences.
So, now I don’t know what to do. Can you please help me with this issue?
Regards,
