Hi , I am doing project on voice recording i have the module and got the code also
but i can’t understand few instructions in this code
1.byte2 = (fileSize >> 8) & 0xff ?
if (recByteCount % totalBuf > bufSplit_1 && lastBuf == 7) ?
OCR2A = valOCR2A; ?
cbi(ADCSRA,ADPS2); , sbi(ADCSRA,ADPS1);, sbi(ADCSRA,ADPS0); ?
ISR(TIMER2_COMPA_vect) ?
for (int dloop = 0; dloop < 4; dloop++) ?
sbi (TIMSK2, OCIE2A); ?
#include <SdFat.h>
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
SdFat sd;
SdFile rec;
const unsigned int darBufSize = 128;
const unsigned int totalBuf = darBufSize * 8;
const unsigned int bufSplit_1 = darBufSize;
const unsigned int bufSplit_2 = darBufSize * 2;
const unsigned int bufSplit_3 = darBufSize * 3;
const unsigned int bufSplit_4 = darBufSize * 4;
const unsigned int bufSplit_5 = darBufSize * 5;
const unsigned int bufSplit_6 = darBufSize * 6;
const unsigned int bufSplit_7 = darBufSize * 7;
const int chipSelect = 4;
unsigned long fileSize = 0L;
unsigned long waveChunk = 16;
unsigned int waveType = 1;
unsigned int numChannels = 1;
//------------ SET SAMPLE RATE HERE --------------------
unsigned long sampleRate = 48000;
unsigned long bytesPerSec = sampleRate;
unsigned int blockAlign = 1;
unsigned int bitsPerSample = 8;
unsigned long dataSize = 0L;
unsigned long recByteCount = 0L;
unsigned long recByteSaved = 0L;
const int btnStart = 6;
const int btnStop = 5;
const int ledStart = 2;
const int ledStop = 3;
int recPressed = 0;
int stopPressed = 0;
unsigned long oldTime = 0L;
unsigned long newTime = 0L;
byte buf00[darBufSize]; // buffer array 1
byte buf01[darBufSize]; // buffer array 2
byte buf02[darBufSize]; // buffer array 3
byte buf03[darBufSize]; // buffer array 4
byte buf04[darBufSize]; // buffer array 4
byte buf05[darBufSize]; // buffer array 4
byte buf06[darBufSize]; // buffer array 4
byte buf07[darBufSize]; // buffer array 4
byte byte1, byte2, byte3, byte4;
unsigned int bufByteCount;
byte bufWrite;
byte lastBuf = 7;
byte valOCR2A = 16000000/(8*sampleRate);
void setup() { // THIS RUNS ONCE
Setup_timer2();
Setup_ADC();
pinMode(10, OUTPUT);
pinMode(ledStart, OUTPUT);
pinMode(ledStop, OUTPUT);
pinMode(btnStop, INPUT_PULLUP);
pinMode(btnStart, INPUT_PULLUP);
if (sd.begin(chipSelect, SPI_FULL_SPEED)) { // initialise card on SPI to 8MHz SPI bus speed
for (int dloop = 0; dloop < 4; dloop++) {
digitalWrite(ledStart,!digitalRead(ledStart));
delay(100);
} else { // if error, flash LED twice per second, until reset
while(1) {
digitalWrite(ledStop,!digitalRead(ledStop));
void loop() { // THIS RUNS LOTS!
if (digitalRead(btnStart) == LOW && recPressed == 0) {
StartRec(); // launch StartRec method
if (digitalRead(btnStop) == LOW && recPressed == 1) {
StopRec(); // launch StopRec method
if (recPressed == 1) {
if (recByteCount % totalBuf > bufSplit_1 && lastBuf == 7) {
rec.write(buf00,darBufSize); lastBuf = 0; recByteSaved += darBufSize;
} else if (recByteCount % totalBuf > bufSplit_2 && lastBuf == 0) {
rec.write(buf01,darBufSize); lastBuf = 1; recByteSaved += darBufSize;
} else if (recByteCount % totalBuf > bufSplit_3 && lastBuf == 1) {
rec.write(buf02,darBufSize); lastBuf = 2; recByteSaved += darBufSize;
} else if (recByteCount % totalBuf > bufSplit_4 && lastBuf == 2) {
rec.write(buf03,darBufSize); lastBuf = 3; recByteSaved += darBufSize;
} else if (recByteCount % totalBuf > bufSplit_5 && lastBuf == 3) {
rec.write(buf04,darBufSize); lastBuf = 4; recByteSaved += darBufSize;
} else if (recByteCount % totalBuf > bufSplit_6 && lastBuf == 4) {
rec.write(buf05,darBufSize); lastBuf = 5; recByteSaved += darBufSize;
} else if (recByteCount % totalBuf > bufSplit_7 && lastBuf == 5) {
rec.write(buf06,darBufSize); lastBuf = 6; recByteSaved += darBufSize;
} else if (recByteCount % totalBuf < bufSplit_1 && lastBuf == 6) {
rec.write(buf07,darBufSize); lastBuf = 7; recByteSaved += darBufSize;
void StartRec() { // begin recording process
digitalWrite(ledStart,HIGH);
digitalWrite(ledStop,LOW);
recByteCount = 0;
bufByteCount = 0;
recByteSaved = 0;
bufWrite = 0;
recPressed = 1; // recording button has been pressed
stopPressed = 0;
writeWavHeader();
sbi (TIMSK2, OCIE2A); // enable timer interrupt, start grabbing audio
void StopRec() { // stop recording process, update WAV header, close file
cbi (TIMSK2, OCIE2A); // disable timer interrupt
writeOutHeader();
digitalWrite(ledStart,LOW); // turn off recording LED
digitalWrite(ledStop,HIGH); // light stop LED
recPressed = 0;
void writeOutHeader() { // update WAV header with final filesize/datasize
rec.seekSet(4);
byte1 = recByteSaved & 0xff;
byte2 = (recByteSaved >> 8) & 0xff;
byte3 = (recByteSaved >> 16) & 0xff;
byte4 = (recByteSaved >> 24) & 0xff;
rec.write(byte1); rec.write(byte2); rec.write(byte3); rec.write(byte4);
rec.seekSet(40);
rec.close();
void writeWavHeader() { // write out original WAV header to file
recByteSaved = 0;
rec.open("rec00000.wav", O_CREAT | O_TRUNC | O_RDWR);
rec.write("RIFF");
byte1 = fileSize & 0xff;
byte2 = (fileSize >> 8) & 0xff;
byte3 = (fileSize >> 16) & 0xff;
byte4 = (fileSize >> 24) & 0xff;
rec.write("WAVE");
rec.write("fmt ");
byte1 = waveChunk & 0xff;
byte2 = (waveChunk >> 8) & 0xff;
byte3 = (waveChunk >> 16) & 0xff;
byte4 = (waveChunk >> 24) & 0xff;
byte1 = waveType & 0xff;
byte2 = (waveType >> 8) & 0xff;
byte1 = numChannels & 0xff;
byte2 = (numChannels >> 8) & 0xff;
byte1 = sampleRate & 0xff;
byte2 = (sampleRate >> 8) & 0xff;
byte3 = (sampleRate >> 16) & 0xff;
byte4 = (sampleRate >> 24) & 0xff;
byte1 = bytesPerSec & 0xff;
byte2 = (bytesPerSec >> 8) & 0xff;
byte3 = (bytesPerSec >> 16) & 0xff;
byte4 = (bytesPerSec >> 24) & 0xff;
byte1 = blockAlign & 0xff;
byte2 = (blockAlign >> 8) & 0xff;
byte1 = bitsPerSample & 0xff;
byte2 = (bitsPerSample >> 8) & 0xff;
rec.write("data");
byte1 = dataSize & 0xff;
byte2 = (dataSize >> 8) & 0xff;
byte3 = (dataSize >> 16) & 0xff;
byte4 = (dataSize >> 24) & 0xff;
void Setup_timer2() {
TCCR2B = _BV(CS21); // Timer2 Clock Prescaler to : 8
TCCR2A = _BV(WGM21); // Interupt frequency = 16MHz / (8 x 62 + 1) ~= 32000Hz
OCR2A = valOCR2A; // Compare Match register set to 62
void Setup_ADC() {
ADMUX = 0x65; // set ADC to read pin A5, ADLAR to 1 (left adjust)
cbi(ADCSRA,ADPS2); // set prescaler to 3 / ADC clock = 4MHz
sbi(ADCSRA,ADPS1);
sbi(ADCSRA,ADPS0);
ISR(TIMER2_COMPA_vect) {
sbi(ADCSRA, ADSC); // start ADC sample
while(bit_is_set(ADCSRA, ADSC)); // wait until ADSC bit goes low = new sample ready
recByteCount++; // increment sample counter
if (recByteCount % totalBuf < bufSplit_1) {
buf00[recByteCount % darBufSize] = ADCH;
} else if (recByteCount % totalBuf < bufSplit_2) {
buf01[recByteCount % darBufSize] = ADCH;
} else if (recByteCount % totalBuf < bufSplit_3) {
buf02[recByteCount % darBufSize] = ADCH;
} else if (recByteCount % totalBuf < bufSplit_4) {
buf03[recByteCount % darBufSize] = ADCH;
} else if (recByteCount % totalBuf < bufSplit_5) {
buf04[recByteCount % darBufSize] = ADCH;
} else if (recByteCount % totalBuf < bufSplit_6) {
buf05[recByteCount % darBufSize] = ADCH;
} else if (recByteCount % totalBuf < bufSplit_7) {
buf06[recByteCount % darBufSize] = ADCH;
buf07[recByteCount % darBufSize] = ADCH;
