What am I doing wrong here?
I'm trying to display the amount of available spaces after a servo goes 90 degrees.
I don't get errors but what I want isn't displayed or compiled?
2nd_Update_Counter.ino (1.04 KB)
KyleXYZ:
Idk, you're the one running the code - only you know what it's outputting.
#include <LiquidCrystal.h>
#include <Servo.h>
#include <EEPROM.h>
LiquidCrystal lcd(1, 2, 4, 5, 6, 7);
Servo servo1;
const int trigPin = 9;
const int echoPin = 10;
long duration;
int distanceCm, distanceInch;
int currentState1 = 0;
int previousState1 = 0;
int Beschikbaar = 0;
int pos;
  servo1.attach(11);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  lcd.begin(16, 2);
  lcd.setCursor(0, 1);
  lcd.print("Beschikbaar");
  lcd.setCursor(4, 0);
  lcd.print("Welcome");
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distanceCm = duration * 0.034 / 2;
  distanceInch = duration * 0.0133 / 2;
  while (distanceCm <= 10)
  { for (pos = 0; pos <= 90; pos += 90) {
      servo1.write(pos);
      delay(2000);
    while (pos = 90) {
      (currentState1 = 1);
    while (currentState1 = 1) {
      (Beschikbaar = Beschikbaar + 1);
    lcd.print(Beschikbaar);
Breaking down your while loop:
while(distanceCm <= 10)
    for (pos = 0; pos <= 90; pos +=90)
        servo1.write(pos);
        delay(2000);
   {break;}
What is your aim here? distanceCm is never updated in this loop.
What is the "{break;} doing?
   while (pos = 90)
        (currentState1 =1);
You're using assignment "=" instead of compare "==" in these.
I'm using a UltraSonic Sensor and a Servo. Whenever an object moves 10cm in front of the US Sensor the servo goes up at a 90 degree angle.
I'm trying to log how many times that happens with the integer "Beschikbaar"
KyleXYZ:
It looks to me like you really need to decide what you are counting. If you move the servo up while the distance is less than 10, i suspect you are moving the servo far more often than you need to, and counting a useless number of actions.
If you move the servo ONCE when the distance BECOMES less than 10, you'll count something meaningful.
