What am i doing wrong ?? UNO >XBEE > XBEE > Uno
I want to built a remote controlled robot platform and send simple (forward, backward, left , right stop) data to the Platform using a XBEE
This is what I came up with
Transmitter:
int UD = 0;
int LR = 0;
int outByte;
  UD = analogRead(A0);
  LR = analogRead(A1);
  //If joystick is Centre
  if (UD >= 510 && UD <= 520 && LR >= 520 && LR <= 530)
    outByte = 'S';
  //If joystick is Up
  if (UD >= 521 && LR >= 520 && LR <= 530)
    outByte = 'F';
  //If joystick is down
  if (UD <= 509 && LR >= 520 && LR <= 530)
    outByte = 'B';
  //If joystick is left
  if (UD >=510 && UD <= 520 && LR <= 519)
    outByte = 'L';
  //If joystick is right
  if (UD >=510 && UD <= 520 && LR >= 531)
    outByte = 'R';
  Serial.print(outByte);
And this is for the receiver site:
int UD = 0;
int LR = 0;
int outByte;
    outByte = 'S';
  //If joystick is Up
    outByte = 'F';
    outByte = 'B';
    outByte = 'L';
    outByte = 'R';
The data does not seem to get to the motor controller.
I tested the joystick with a sample sketch : works
I tested the motor shield : works
I tested the XBee's transmitting simple setup: http://arduino.cc/en/Guide/ArduinoWirelessShieldS2 works
When I Hook the transmitter to the serial monitor I get the good values.
What did i do wrong?
SOLVED
I didn't give any values to the motors......
Stupid mistake
