What am I doing wrong?
I am trying to use analog potentiometer inputs and convert them to digital outputs. I read that the digital outputs are in-between the values 0 and 1023, so I wrote the following code:
//reads analog and converts to digital
//then it uses the digital output to turn on LEDs
int red = 7;
int green = 8;
int yellow = 9;
int val = 0;
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(yellow, OUTPUT);
val = analogRead(A2);
Serial.println(val);
delay(1);
if (val >= 0 || val <= 255)
digitalWrite(red, HIGH);
else if(val >= 256 || val <= 511)
digitalWrite(yellow, HIGH);
else if(val >= 512 || val <=1023)
digitalWrite(green, HIGH);
There are no compiling errors.
The problem is only the red LED turns on and stays on. When I turn the potentiometer nothing else happens.
I am using an Elektor R4 board.
My TX LED is always on and my computer is connected to the board
I am also new to Arduino so please go easy on me. Am I doing something wrong, and is there an easier way to accomplish this?
Any value of val read from the pot will be greater than 0.
I suspect you meant
if (val >= 0 && val  <= 255)  //and instead of or in the comparison
in order to act on a value between 0 and 255 and so on for other ranges.
Thank you, I will try this when I get back from school.
There's also no code to turn any of those leds off, so once they're on they're on for good.
Yes everything works perfectly, forgot about turning off the LEDs too, thank you for that.
