What am i doing wrong?
Hey,
After receiving a lot of help on this project offer the past few weeks, i would like to start by saying that the guys on this forum have assisted me a lot and i would have not got to the point i am at not. So a huge thank you!
It feels like i am now at the last hurdle and I seem to be staring at the screen, scrolling through the code and not knowing whats wrong...
The code below, checks a cable to see what type it is, sets how many pins it should be checking for and then sees if the cable passes its test. The code works fine if the cable type matches. But if it does not it misses checking Pin 2.
Any help would be much appreciated
LiquidCrystal_I2C lcd(0x27,20,4);
String Line1;
String Line2;
String Line3;
String Line4;
uint8_t outPins[] = {2, 0, 4, 5, 6};// Output pins
uint8_t inpPins[] = {7, 0, 9, 10, 11};// Input pins
uint8_t outConnectorPins[] = {26, 28, 30, 32, 34 ,36 ,38,  40, 42, 44, 46, 48, 50};// Check what cable is conencted Pins MALE
uint8_t inConnectorPins[] = {27, 29, 31, 33, 35, 37, 39, 41, 43, 45, 47, 49, 51};// Check what cable is conencted Pins FEMALE
int pinsToCheck = 0;
int run;
int inputPinAmount = 0;
int outputPinAmount = 0;
const int sensePin = 2;     // the number of the pushbutton pin
const int readPin = 7;     // the number of the pushbutton pin
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
int buttonState = 0;         // variable for reading the pushbutton status
int lastButtonState = 0;
// LCD SCROLLING SETUP //
void lcdPrint(String lcdText)
    lcd.clear();
    Line1 = Line2;
    lcd.setCursor(4, 0);
    lcd.print(Line1);
    Line2 = Line3;
    lcd.setCursor(4, 1);
    lcd.print(Line2);
    Line3 = Line4;
    lcd.setCursor(4, 2);
    lcd.print(Line3);
    Line4 = lcdText;
    Line4.replace("\r\n", "");
    lcd.setCursor(4, 3);
    lcd.print(Line4);
    Line1 = "";
    lcdText = "";
  lcd.begin();
  lcd.backlight();
  lcd.setCursor(4,2);
  lcd.print("Cable Tester");
  pinMode(readPin, INPUT); //set the button pin as INPUT
  pinMode(sensePin, OUTPUT); //set the LED pin as OUTPUT
  pinMode(sensePin,OUTPUT);
  digitalWrite(sensePin, HIGH); // Set Output Sensor Pin to High
  pinMode(readPin,INPUT);
  int buttonState = digitalRead(readPin); //read the state of Input Sensor Pin
  if(lastButtonState != buttonState)
    if(buttonState == 1) // Cable has been connected
      lastButtonState = 1;
      cableConnected();
      lastButtonState = 0; // Cable has been Disconnected
      cableDisonnected();
void cableConnected()
        lcd.clear();
        lcd.setCursor(2,1);
        lcd.print("Cable Connected");
        lcd.clear();
        checkWhatCable();
void checkWhatCable()
  lcd.clear();
  lcdPrint("");
  lcdPrint("");
  lcdPrint("");
  lcdPrint("");
int femalePin;
int malePin;
        for (uint8_t m = 0; m < sizeof(outConnectorPins); m++) // Setup output pins
          pinMode(outConnectorPins[m],OUTPUT);
          digitalWrite(outConnectorPins[m],LOW);
        for (uint8_t f = 0; f < sizeof(inConnectorPins); f++) // Setup input pins
          pinMode(inConnectorPins[f],INPUT); // Turn off internap pullup resistor
        for (uint8_t o = 0; o < sizeof(outConnectorPins); o++) // Setup Female input pins
          digitalWrite(outConnectorPins[o],HIGH); // Set pin high
          for (uint8_t i = 0; i < sizeof(inConnectorPins); i++)// Scan input pins
            if (digitalRead(inConnectorPins[i]) == HIGH) // If pin is high must be connected to output
              femalePin = inConnectorPins[o]; // input
              inpPins[1] = femalePin;
              lcd.setCursor(4,0);
              if (femalePin == 27)
                lcd.print("16A 1 Phase");
                inputPinAmount = 3;
              else if (femalePin == 29)
                lcd.print("32A 1 Phase");
                inputPinAmount = 3;
              malePin = (outConnectorPins[i]); // Input
              outPins[1] = malePin;
              lcd.setCursor(4,2);
              if (malePin == 26)
                outputPinAmount = 3;
              else if (malePin == 28)
              delay(2000);
          digitalWrite(outConnectorPins[o],LOW); // Set output back to low
        setPinModes();
void setPinModes()
        for (uint8_t i = 0; i < sizeof(outPins); i++) // Setup output pins
          pinMode(outPins[i],OUTPUT);
          digitalWrite(i,LOW);
        for (uint8_t i = 0; i < sizeof(inpPins); i++) // Setup input pins
          pinMode(inpPins[i],INPUT); // Turn off internap pullup resistor
        Serial.println("Begin Test");
        if (testCable() == true)
          lcdPrint("** Passed **");
          Serial.println("** Passed **");
          lcdPrint("** Failed **");
          Serial.println("** Failed **");
bool testCable()
  lcd.clear();
  if (inputPinAmount > outputPinAmount)
    pinsToCheck = inputPinAmount;
    pinsToCheck = outputPinAmount;
  bool testResult = true;                         // Assume cable is good
  uint8_t count = 0;                              // Count of correct connections
  if (sizeof(outPins) != sizeof(inpPins)) // Array sizes match?
    Serial.println(F("ERROR: Array Sizes Do Not Match."));
    return false; // Exit now
  for (uint8_t o = 0;  o < sizeof(outPins); o++)// Loop though output pins
    Serial.print("Pin \t");
    Serial.print(o);
    digitalWrite(outPins[o],HIGH); // Set pin high
    if (digitalRead(inpPins[o]) == HIGH)// Everything is OKAY that pin works
      count++; // Increment count
      Serial.print("->");                          // Display it as first pin
      Serial.print(o);                            // Display it as first pin
      int a = (o +1);
      String myStr;
      myStr=String(a);
      lcdPrint(myStr + " -> " + myStr);
// If there is issues with the cable test, see what cables are crossed///
    for (uint8_t i = 0; i < sizeof(inpPins); i++)// Scan input pins
      if (digitalRead(inpPins[i]) == HIGH) // If pin is high must be connected to output
        if (o != i) // If array numbers don't match then must be error  <--------------------ERROR
          Serial.print(" X ");
          Serial.print(i +1);
          //testResult = false;  // Somethings Wrong show Error
          int a = (o +1); //Output
          String myStr;
          int b = (i +1); // Input
          String myStr2;
          myStr=String(a); //Output
          myStr2=String(b); // Input
          lcdPrint(myStr + " X " + myStr2); // Show Errors
    digitalWrite(outPins[o],LOW); // Set output back to low
    Serial.println(); // New line ready for next pin
  if (count < pinsToCheck) // Have we had the correct number of correct pins?
    testResult = false; // If not then must be error
    testResult = true;
  return testResult;
void cableDisonnected()
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print("Cable Disconnected");
Pin 2 is in this array of pins
But it is also used here
Is that correct ?
Pin 7 seems also to be used twice
void setPinModes()
Oops
UKHeliBob:
Is that correct ?
Hey,
Good spot but this is meant to be used. Just see's if the cable i connected on pin 1 of the cable. Then runs through the test of all cores
TheMemberFormerlyKnownAsAWOL:
void setPinModes()
Oops
Sorry, not sure what i am looking at here?
Probably use this instead
digitalWrite(outPins[i],LOW);
Just looking through the code again this morning.
I can't help thinking its something to do with this area....
guix:
Just changed that and it didn't solve the issue... >:(
eddcaton:
But it made it better, and with a greater chance of working correctly later.
Post your current code
String Line1;
String Line2;
String Line3;
String Line4;
int run;
    lcd.clear();
    Line1 = Line2;
    lcd.print(Line1);
    Line2 = Line3;
    lcd.print(Line2);
    Line3 = Line4;
    lcd.print(Line3);
    Line4 = lcdText;
    lcd.print(Line4);
    Line1 = "";
    lcdText = "";
  lcd.begin();
  lcd.backlight();
  lcd.setCursor(4,2);
      cableConnected();
      cableDisonnected();
        lcd.clear();
        lcd.setCursor(2,1);
        lcd.clear();
        checkWhatCable();
  lcd.clear();
  lcdPrint("");
  lcdPrint("");
  lcdPrint("");
  lcdPrint("");
int femalePin;
int malePin;
              lcd.setCursor(4,0);
                inputPinAmount = 3;
                inputPinAmount = 3;
              lcd.setCursor(4,2);
              if (malePin == 26)
              delay(2000);
        setPinModes();
void setPinModes()
bool testCable()
  lcd.clear();
    Serial.print(o);
      int a = (o +1);
      String myStr;
      myStr=String(a);
          Serial.print(i +1);
          String myStr;
          String myStr2;
    testResult = true;
  return testResult;
        lcd.clear();
        lcd.setCursor(0,0);
It looks like you use pin zero as an input and an output. The serial port uses it too.
wildbill:
Hey,
The 0 pin for input and output is replaced by:
femalePin = inConnectorPins[o]; // input[color=#222222][/color]
And
malePin = (outConnectorPins[i]); // Input[color=#222222][/color]
I have done some more testing and found that.
If the outPins[1] and inpPins[1] are consecutive numbers like 26 and 27, the code tests fine.
When they are not consecutive, that is then the code does not test pin 2.
Could it be something to do with the for loops within the testCable function ?
More testing today, but still no luck with finding a solution as of yet.
I tested all the inpPins are showing as high when the Testcable function is run by using:
Serial.print(digitalRead (inpPins[o]));
It looks like the inpPin[1] is not reading as high, hence which its not testing the pin.
But as before if i plug the jumper cable in consecutive numbers 26 and 27 it sees the HIGH pin... :confused: But when its say 26 and 31 it does not see the high pin.
