What am I missing in my code?
I had a working code on the test bench and went and installed it in machine and I cant seem to get it to work. Ive double checked my wiring. I did make some edits to the file earlier but I cant figure out what I might have done? Did I accidently delete a bracket or something? Or is it hardware related
#include <JC_Button.h>
const int ButtonCount = 6;
const byte ButtonPins[ButtonCount] = {2, 3, 4, 5, 6, 7}; //first button is on pin 2
const int relay1 = 10; //relay1 signal is pin 10
int TurnOnCode[] = {6, 5, 5, 4, 3, 2};
const int TurnOnCodeCount = sizeof TurnOnCode / sizeof TurnOnCode[0];
int TurnOnCorrectCount = 0; // How many have been entered
int TurnOffCode[] = {1, 1, 1};
const int TurnOffCodeCount = sizeof TurnOffCode / sizeof TurnOffCode[0];
int TurnOffCorrectCount = 0; // How many have been entered
boolean ButtonWasPressed[ButtonCount];  // Defaults to 'false'
unsigned long ButtonStateChangeTime = 0; // Debounce timer common to all buttons
const unsigned long DebounceTime = 30;
void setup()  //run once at sketch startup
  Serial.begin(9600); //begin Serial
  for (int i = 0; i < ButtonCount; i++)
    pinMode(ButtonPins[i], INPUT_PULLUP);
  pinMode(relay1, OUTPUT); // relay1 is an output
  Serial.print("Turn On code: ");
  for (int i = 0; i < TurnOnCodeCount; i++)
    Serial.print(TurnOnCode[i]); //print each digit of the code
  Serial.print("Turn Off code: ");
  for (int i = 0; i < TurnOffCodeCount; i++)
    Serial.print(TurnOffCode[i]); //print each digit of the code
void loop()  //run repeatedly
  unsigned long currentTime = millis();
  // Check each button
    boolean buttonIsPressed = digitalRead(ButtonPins[i]) == LOW;
    boolean buttonHasBounced = currentTime - ButtonStateChangeTime > DebounceTime;
    if (buttonIsPressed != ButtonWasPressed[i] && buttonHasBounced)
      ButtonStateChangeTime = currentTime;
      ButtonWasPressed[i] = buttonIsPressed;
      if (ButtonWasPressed[i])
        checkEntered(i + 1); //call checkEntered and pass it the button number
void checkEntered(int button)  //check the button press
  // Check against turn-on code
  if (button == TurnOnCode[TurnOnCorrectCount])
    TurnOnCorrectCount++;
    if (TurnOnCorrectCount == TurnOnCodeCount)
      // Success!
      digitalWrite(relay1, HIGH); //turn relay1 on
      // Start over
  else // Not the correct button
    TurnOnCorrectCount = 0; // Start over
  // Check against turn-off code
  if (button == TurnOffCode[TurnOffCorrectCount])
    TurnOffCorrectCount++;
    if (TurnOffCorrectCount == TurnOffCodeCount)
      // Success!
      digitalWrite(relay1, LOW); //turn relay1 off
      // Start over
    TurnOffCorrectCount = 0; // Start over
At a glance it looks like you need to enter the buttons in order on e each.
Do you mean to have 5 twice?
Oh, wait, still figuring out how the combo works.
a7
i just figured it out it was a wire not making contact in terminal cleaned insulation and now its working
Please mark the thread as solved so that other members that wish to help will not waste their time opening the thread only to find that you no longer need help.
I hate when that happens. :wink:
Now while you are thinking about it, do whatever it is that you do to keep a copy of a known functioning sketch available for occasions like you might have messed with something a little bit, or a little bit too much.
I do rely on a backup system that lets me step back in time but I also zip project documnets and make my own snapshots. I toss everything I think I'd need to do it all over in there.
a7
