What am i missing? (using Interrupt)
Hello.
So I have been struggling with some code.
I use MKRGSM1400 and a switch connected to pin 7.
This code works, and it count pulses.
But running it together with some GSM and RS485 stuff i doesnt work at all.
Am I missing something?
const byte interruptPin = 7;  //digitalPinToInterrupt
uint16_t mCounter = 0;
  countBegin();
  debugStart();
  debugPoll(String(mCounter));
void countBegin()
  pinMode(interruptPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(interruptPin), countISR, FALLING);
void countISR() { mCounter++; }
void debugStart() { SerialUSB.begin(9600); }
void debugPoll(String what) {
 if (SerialUSB) {
    static uint32_t eee = 0;
    const uint8_t interval = 2;
    if (millis() - eee >= interval*1000UL) { SerialUSB.print(" >"); Serial.print(String(what)); eee=millis(); }
Aha, I think i found it.
Forgot about the MKRGPS (i2C) module.
Disabling that enabled the interrupt.
You encountered the same thing I did. I began using the I2C port and discovered that I/O pin 7 was wired to the socket. I use the GPS shield and it gives you control over the power usage. I had already been using the pin for sleep/wake functions and discovered the dual assignment of functions after my sleep/wake stopped working.
