howiel
July 25, 2022, 2:41am
1
Every Serial.println() returns -1.
What have I missed?
float num1 = 0.0;
float num2 = 1.234567;
float num3 = -23.45679;
float num4 = 123.456789;
float num5 = -234.567;
while (!Serial);
Serial.println(printf( "%+8.5", num1));
Serial.println(printf( "%+8.5", num2));
Serial.println(printf( "%+8.5", num3));
Serial.println(printf( "%+8.5", num4));
Serial.println(printf( "%+8.5", num5));
What MCU are you using? As far as I know, printf() is not implemented on any genuine Arduino.
Do you actually need it?
What's wrong with the following?
Serial.println(num1, 5);
Serial.println(num2, 5);
Serial.println(num3, 5);
Serial.println(num4, 5);
Serial.println(num5, 5);
That does not make sense. printf, if enabled, prints to Serial. So the enclosing println is printing the return value returned by printf, which is the number of characters printf printed. Is that really what you intended?
And your printf format strings are not value, as they do not specify and format. For floating point, the format should be "f". This this instead:
printf( "%8.5f", num1);
howiel
July 25, 2022, 3:04am
6
Yes I do. I'm outputting a latitude and longitude and I need leading + and other formatting.
On the Arduino Nano, use Serial.print(), or dtostrf() then Serial.print().
Floating point format is by default not implemented for s(n)printf() on the Arduino Nano.
howiel
July 25, 2022, 3:08am
8
OK, I see where you're coming from. I'll have to rethink it. Ta
dougp
July 25, 2022, 3:49am
9
Would Libprintf.h work on a Nano?
system
Closed
January 21, 2023, 3:49am
10
