What am I overlooking? Why isn't Bar printing?
//PSPS for use in Arduino IDE.             Corresponding ATMega328P-AU TQFP32 pin
const int cutOut = 1;                               //31
const int  buttonPinOff = 0;                        // the interrupt pin that the OFF interupt pushbutton is attached to
const int  buttonPinOn = 1;                         // the interrupt pin that the ON interupt pushbutton is attached to
const int solenoid = 4;                             // solenoid connected to digital pin 4 on arduino.
int const cutIn = 5;                                //32
int const pumpPin = 6;                              //1
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd (7,8,9,10,11,12);              //11RS,12E,13D4,14D5,15D6,16D7
//LED Stuff1of3
int led = 13;                                    //16
//PSI and Bar Stuff
int mpxVal = 0;
int mpxValBar = 0;
const int MIN_PSI= 0;                         //constraint stuff
const int MAX_PSI= 1023;                      //constraint stuff
const int MIN_Bar= 0;                      //constraint stuff
const int MAX_Bar= 7;                      //constraint stuff
int mpxPin = A0;                                 //23
int mpxPin1 = A0;                                 //23
// Variables will change:
volatile int buttonPushCounterOn = 0;            // counter for the number of button presses
volatile int buttonPushCounterOff = 0;           // counter for the number of button presses
volatile int buttonStateOn = 0;                  // current state of the button
int buttonStateOff = 0;                          // current state of the button
int lastButtonStateOn = 0;                       // previous state of the On button
int lastButtonStateOff = 0;                      // previous state of the Off button */
unsigned long lastSwitchOnTime  = 0;             //Debounce Stuff
unsigned long lastSwitchOffTime  = 0;            //Debounce Stuff
long previousMillis = 0;                         // BLINK WITHOUT DELAY STUFF. Will store last time millis updated
void setup(){
  pinMode(solenoid, OUTPUT);                     // sets the digital pins as in/output
  pinMode(cutIn, INPUT);
  pinMode(cutOut, INPUT);
  pinMode(pumpPin, OUTPUT);
  pinMode(buttonPinOn, INPUT);
  pinMode(buttonPinOff, INPUT);
  //LED Stuff2of3
  pinMode(led, OUTPUT);
  //Serial Stuff1of2
  //Serial.begin(9600);
  lcd.begin(16,2);                               // set up the LCD's number of columns and rows:
  lcd.print("www.MISTFITZ.com");                 // Print a message to the LCD.
  delay(4000);
  lcd.clear();
  lcd.setCursor(2,1);
  lcd.print("-S.ON");
  lcd.setCursor(10,1);
  lcd.print("-M.OFF");
  attachInterrupt(buttonPinOn, isr1 ,RISING);
  attachInterrupt(buttonPinOff, isr2 ,RISING);
void isr1()
  if(millis() - lastSwitchOnTime > 150)          // Debounce: Ignore any events that happen within __ milliseconds of the last one
    buttonPushCounterOn+=1;
    if(buttonPushCounterOn > 60)buttonPushCounterOn =0;    // rollover after 60.
  lastSwitchOnTime = millis();
void isr2()
  if(millis() - lastSwitchOffTime > 150)        // Debounce: Ignore any events that happen within __ milliseconds of the last one
    buttonPushCounterOff+=1;
    if(buttonPushCounterOff > 60)buttonPushCounterOff =0;    // rollover after 60.
  lastSwitchOffTime = millis();
void loop(){
  //Read the MPX sensor
  mpxValBar = analogRead(mpxPin1);
  mpxVal = analogRead(mpxPin);
  //PSI /Bar maths.. incomplete
  mpxVal = map(mpxVal * .98, MIN_PSI, MAX_PSI, 0, 101);
  mpxVal = constrain(mpxVal, 0, 101);
  mpxValBar = map(mpxValBar * .98, MIN_Bar, MAX_Bar, 0, 7);
  mpxValBar = constrain(mpxValBar, 0, 7);
  //Serial Stuff2of2
  //Serial.println(mpxVal, DEC); // Display pressure value.
  //delay (400);
  // On/Off Pressure Selection Switches
  //ON LOGIChigh: If the "on" slide switch is HIGH (indicating we want on at 40) and the pressure is  40 or less the pump will turn on at 40.
  if (digitalRead(cutIn) == HIGH && mpxVal <= 40){
    digitalWrite(pumpPin, HIGH);
    digitalWrite(led, HIGH);
  //ON LOGIClow: But if the "on" slide switch is LOW (indicating we want on at 50)and pressure is 50 or less the pump will turn on at 50.
  else if (digitalRead(cutIn) == LOW && mpxVal <= 50){
  //OFF LOGIChigh: If the "off" slide switch is HIGH (indicating we want off at 60) and the pressure is 60 or greater the pump will turn on at 60.
  if (digitalRead(cutOut) == HIGH && mpxVal >= 60){
    digitalWrite(pumpPin, LOW);
    digitalWrite(led, LOW);
  //OFF LOGIClow: If the "off" slide switch is LOW (indicating we want off at 70) and the pressure is 70 or greater the pump will turn on at 70.
  else if (digitalRead(cutOut) == LOW && mpxVal >= 70){
  //BLINK WITHOUT DELAY
    if(currentMillis  > previousMillis) {
      if(digitalRead(solenoid)){
        digitalWrite(solenoid,LOW);
        previousMillis = currentMillis + buttonPushCounterOff * 60000; // X 60000 for minutes.
      else {
        digitalWrite(solenoid,HIGH);
        previousMillis = currentMillis + buttonPushCounterOn *1000;  // X 1000 for seconds.
    // (note: line 1 is the second row, since counting begins with 0):
    // print current pressure value:  PSI
    lcd.setCursor(1,0);
    lcd.print("  ");
    lcd.setCursor(2, 0);
    lcd.print(mpxVal, DEC);
    lcd.print("PSI / ");
    // print current pressure value: Bar
    lcd.setCursor(9,0);
    lcd.print("  ");
    lcd.setCursor(12, 0);
    lcd.print(mpxValBar, DEC);
    lcd.print("Bar");
    lcd.setCursor(1,1);
    lcd.print(" ");
    lcd.setCursor(0,1);
    lcd.print(buttonPushCounterOn,DEC);
    lcd.setCursor(9,1);
    lcd.print(" ");
    lcd.setCursor(8,1);
    lcd.print(buttonPushCounterOff,DEC);
Do you mean this part:
Alphafitz:     lcd.setCursor(12, 0);      lcd.print(mpxValBar, DEC);     lcd.print("Bar");
Perhaps there is not enough room in the last four characters of the line to put the number and the word "Bar"?
