I am changing from an Uno, to a Mega for my Coin Counter project. I am not quite sure what pins to use for fuor(4) of
these: LM393 Chip Motor Measuring Comparator Speed Sensor Module Slot Type IR Optocoupler for MCU Arduino
• Product Name : Speed Sensor Module;Working Voltage : DC 3.3-12V
• Main Chip : LM393;PCB Board Size : 33 x 14mm/ 1.3" x 0.55" (L*W)
• Slotted Width : 5mm/ 0.2";Hole Size : 3mm/ 0.12"
• VCC: Connect the positive 3.3v-5v power supply
• GND: Connect power negative
• DO: TTL switch signal output
• AO: This module does not work, The module do not have
I am not quite understanding the inout's I have seen on the pinout map for Mega.
I was using a IR sensor that had Analog output. Switching to Digital output (Different sensors), and Switching to a Mega. The sensor board does not supply analog output.
What is the problem? The Mega has plenty of analog and digital pins. Please post a schematic or connection information for the module you're using now.
I am to the point of trying to determine what digital pins I use. can I utilize any of the digital pins? I do not have the wiring figured out to this point.
How many times do I have to ask? You still haven't posted usable information about the module. "part1, part2, part3" is even less than you posted in the first message...
I read your original post. I see a lot of text. I'm asking for real information like pinouts and specifications. How about a link to the actual sensor you're using?
Partially, I'm asking because of vague and confusing statements like,
"• AO: This module does not work, The module do not have"
