What are some ICs for advanced analog electronics?
Hi all, I recently finished building some basic analog circuits including some Op Amps,555 timer,logic gates and flip flops,
What are some ICs for making some advanced analog circuits?
In respect of what?
Not best known in analogue circles
AWOL:
In respect of what?
From analog I mean not using any microcontroller
Do some rsearch on: Comparators, OP amps, Differential Amps, Current sources, Voltage regulators, Oscillators, Phase-locked Loops, Waveform Generators
Anshul333:
So you don't mean analogue at all then.
I reiterate phase-locked-loops as an interesting advanced chip, so 74HC4046,
gilbert cell mixer like the NE612, things like switched capacitor filters,
nucket-brigade delay line (if you can ever find one!), state variable filter / biquad
filter chips like the nearly-unobtanium UAF42 (these days you'll just use discrete
capacitors and a quad opamp)
For reading "The Art of Electronics" suggests itself as having a lot of analog circuits of
many kinds.
For a real challenge (I keep thinking about making one of these, never get round to it),
a state-of-the-art low distortion audio oscillator as described in http://www.janascard.cz/PDF/An%20ultra%20low%20distortion%20oscillator%20with%20THD%20below%20-140%20dB.pdf
I think you will find it is spelt nought. :slight_smile:
You really should research the difference between analog & digital...
For more-complex digital chips that are not microcontrollers, check-out [u]PLDs[/u].
There are LOTS of special-purpose analog, digital, and mixed-signal chips. For example, you can get a "soundcard on a chip". I'm pretty sure those cheap USB soundcards are a single chip. Or, the [u]WS2812[/u] "Neopixel" chip is rather complex. Or, voltage regulators (linear or switching).
A lot of analog circuits are built-around op-amps or special-purpose amplifier chips that are essentially op-amps with special features or enhanced specs.
