what are the MKR env shield ranges?
According to MKR ENV reference guide at Arduino_MKRENV - Arduino Reference, the values for the sensor are
  • Absolute pressure range: 260 to 1260 hPa
  • Humidity range: 0 - 100%; accuracy: ± 3.5% rH, 20 to +80% rH
  • Temperature range -40 +120; accuracy: ± 0.5 °C, 15 to +40 °C
  • Lux range of the sensor with analog reading from 10 to 100.000 lux
  • UVA/UVB resolution: 16bit; unit μW/cm2
  • UVIndex: from 1 to 11+ as explained here.
a) For absolute pressure the range appears to be not in hPa but in kPA and it varies from 26 to 126 kPA as per Arduino_MKRENV - Arduino Reference. Is this accurate?
b) What would be the value ranges for UVA and UVB. According to (http://wiki.xinabox.cc/Luminosity,_UVA,_UVB_Lesson#:~:text=UVA%20is%20further%20divided%20into,does%20not%20reach%20the%20earth) uva ranges from 320 to 400 nm and 290 to 320 nm
Is this accurate?
It returns a float, so the answer is probably yes but as you don't define what "accurate" means for you this might be wrong.
The library returns a µW/cm2 (intensity, not wave length). The sensitivity is probably not the same over the whole wave length range but the datasheet of the sensor has a diagram that gives you a clue what you can expect.
