Hello. I am looking for a battery solution to power my Mega 2560, L298N, and 2x 9V DC motors. I need about 11-12v due to the voltage drop by the L298N. At first, I was looking at buying some 18650 cells and 3S Series battery holder on Amazon, but I am a bit worried since I cannot find any battery holders that support button top 18650 protected cells. My next thought was to buy a LiPO RC car battery, but I was hoping to find something a bit smaller. Any ideas? Would it be fine to use unprotected 18650 cells and connect them directly to the Arduino if I manually monitor the voltage for over-discharge? I plan on buying a proper charger if I decide to go this route.
The ancient, inefficient L298 wastes an incredible amount of battery energy as heat.
So, your first and best move is to replace that dinosaur with a modern, switching motor driver. Pololu has the best selection. The improved robot will require less battery capacity.
+1 for Pololu DC motor drivers.
I use the battery from my cheap 12V cordless drill to power my little robot. It has all of the protections built in. I made a slide mount with my 3D printer that mimics the mount on the drill. And I can charge the battery with the supplied charger.
I cannot size it until I know the load and time requirement of the battery. I could oversize it and it will last longer but I could undersize it and you would not be happy. Post the electrical requirements and links to technical information on the hadare devices.
I am using DG01D-E motors with encoders. Each motor draws about 150-160mA at full power. Stall current is 260mA per motor at 9V. I'm looking for 1-2 hours of battery. I will eventually add a Bosch IMU (BNO055) which draws an average of 3.5mA.
How about links and the rest of the hardware, the Mega uses power also.
